Go Back   RC-Monster Forums > Support Forums > Team Tekin
heat and heat again!!!
e-mike
e-mike's Avatar
heat and heat again!!! - 09.19.2009, 10:29 PM
so i converted a mbx5 buggy and ive put my rx8/1700kv truggy combo geared 16/46 on 5cell lipo 5000mah 25c
good air flow/timing lowest/start power off/120k in center diff
after 15 minutes of runtime(track time) my motor reach 174f..esc 98f,lipo 90f
wtf this setup suposed to be cold as ice,,,,,
maybe im undergeared!!?????
D8t on juice!!
FG101C
09.20.2009, 01:59 AM
One thing I've learned from this site is 90% of the people that post temps never actually do it on a track. The track is a whole different ballgame. You're esc and battery temps are ok, and from my experience the motor is actually ok to.
The other thing I've learned, this all through expensive trial and error, is that 31,000 to 35,000 is not the sweet spot for racing, it's more like 25,000 to 29,000. 174 on the motor is ok, try going up a tooth and down a tooth and see were it temps. Also if you can, put the truggy ring and pinions on the diffs, that will help alot too.
TekinTeamMgr
TekinTeamMgr's Avatar
09.20.2009, 10:40 PM
The motor temp is fine. Race speeds for 15 minutes that is good. Where is your timing set?
  Send a message via Yahoo to TekinTeamMgr
e-mike
e-mike's Avatar
09.20.2009, 11:02 PM
lowest...so today ive tried with current limiter( 45) it was better(168f)
i guest im little overpowered for my buggy the same settup(1700kv truggy combo) was cooler in my e-revo at 6cell lipo(144f on the motor)geared for the similar speed...
so if you say that im ok....
thanks TekinTeamMgr..!!
D8t on juice!!
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
09.22.2009, 02:40 PM
Also, make sure you have good airflow to the motor, you are running 0 timing, and you are smooth on the throttle. The number of oscillations that your finger moves back and forth per lap ideally would be equal to the number of turns plus jumps on the track.
Recently my 1900 ran a 30 minute A-main with one battery swap. I finished 2nd and motor temps were 134F. After a 10 min main in a small indoor track temps are between 115 and 123. This is all because I follow all of the rules I mentioned. Others running tekin motors in the same race seem to get temps at least 25 degrees warmer.
Area 52 Ranch Raceway
T.R.C.R.
TekinTeamMgr
09.22.2009, 05:03 PM
I'm just a stickler for running the right motor in the right application.
I'd rather not turn a motor down if I don't have to. Seeing what adjustments you're making I would suggest a slower motor all together. Like the 1550 or 1400.
