Antenna Setup for Speed Runs
kazuaki
Antenna Setup for Speed Runs - 09.23.2009, 11:30 PM
What are others doing with their receiver antenna on speed run setups? My Ko Propo KR-407S 2.4Ghz receiver has an 8" antenna wire. For speed runs I need to have good range. Of course I can always do the standard vertical antenna tube. Is there another setup that might keep the antenna inside the body and get similar range? I've seen some spektrum receivers with super short antennas, but this one is a full 8". Ideas?
09.24.2009, 01:04 AM
I'd just do an 8" antenna tube but bent and ran under the body. If you run it outside the body and end up sliding on your lid you can kiss the antenna goodbye.
kazuaki
09.24.2009, 01:28 AM
So the antenna will be horizontal, basically laying on the chassis. Think that will sacrifice a bunch of range?
George16
Supermaxx
George16's Avatar
09.24.2009, 02:25 AM
I never had any range issues coiling the antenna on my Futaba 2.4GHz radio.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
phildogg
phildogg's Avatar
09.24.2009, 09:47 AM
I run a futaba 2.4 and run mine inside the body with no problems.
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
Rivermaxx
09.24.2009, 10:31 AM
I ran the antenna coiled up in my reciever box and still had good range. Nomadio react I am making a stub antenna for possibly better range though.
J57ltr
09.24.2009, 11:03 AM
I run a Airtronics MX-3 and have no range issues running mine under the body. I can run it so far that I have a hard time telling what direction I am going.
Jeff
speedemall
09.24.2009, 01:05 PM
I run spektrum so the RX wire is already short,so short that it is completely concealed under the body.
