HPI Vorza Flux HP
Marvin
THE Paranoid Android
Marvin's Avatar
HPI Vorza Flux HP - 09.10.2009, 03:55 PM
Just saw this over on oOple.
HPI Vorza Flux HP, basically, what the Ve8 should have been.
In the beginning the Universe was created.
This has made a lot of people very angry and has been widely regarded as a bad move.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
09.10.2009, 04:01 PM
Well I have to say I like the battery tray and the wire holder on the rear chassis brace. I'm sure HPI will sells of them !
brushlessboy16
brushlessboy16's Avatar
09.10.2009, 04:12 PM
looks good, is the motor mount adjustable?
Few other observatons- I like the esc mounting on the car, and wire routing clips built in.
I also like the adjustable battery trays. thats a first
Why put a heatsink on an already finned motor?
And I love this..
Optional parts- 22t pinion, 46t spur, 2650kv motor and 6s lipo....wait a minute. that sounds really fishy..
Why cant manufacturer's create and rate there products with down to earth setups..
09.10.2009, 04:51 PM
Naughty CC should call them on that 2650kv is only rated to 4s...
PS I believe it will take it though - I used to run mine on 5s until castle said no...
wallot
wallot's Avatar
09.10.2009, 04:52 PM
thats normal.
first question of RC newbie is : "How fast does it go?"
the second : "How much does it cost?"
it takes a while for them to realize that offroad vehicle going 40+ mph is very hard to control making it almost useless except speed runs.
sad thing is that racing part of HPI - Hot bodies make plastic car and HPI makes standard D8 conversion.
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
09.11.2009, 03:51 AM
"25c minumum" lipo packs, yet you can run nimh's
and they say "4000mah minumum" for nimh's
rootar
rootar's Avatar
09.11.2009, 09:10 AM
i thought it said no nimh or stick packs or tamiya connectors and no adapters...
wallot
wallot's Avatar
09.11.2009, 09:42 AM
you would be suprised what can racing NIMH packs survive :)
used to run in my Neu powered max 16 racing NIMH cells and they did quite well (before they exploded after 3 months of heavy running without much rest after run I put them on charger @ 5.5Amps, 4-5 cycles in one afternoon )
Radek
*EX-10 Eurus*
76Bentley
09.11.2009, 11:40 AM
I thought I read on rccaraction.com that the buggy came with the 2200kv motor.
Marvin
Marvin's Avatar
09.11.2009, 12:18 PM
It does, but what HPI have said is that it'll do 'x' mph with the following optional parts, which in this case is 6S and the 2650kV motor.
76Bentley
09.11.2009, 02:58 PM
Wow good eyes, I did not see that until you pointed that out in the fine print. I had read over what it comes with on rc car action, but had not looked closely at HPI's stuff. I hope Castle slaps them on the head for that one, it is stuff like that which will cause headaches down the road. People buying the 2650 motor and running it on 6s then wanting it to be covered when it goes poof.
Marvin
Marvin's Avatar
09.11.2009, 03:08 PM
Yeah, I totally agree. Any noob will buy that and say 'well HPI reckon that I can do x mph by overgearing a motor and running on too high a voltage. I'll go for that!'
I think it'll come back to haunt HPI.
TexasSP
Something, anything, nothing
TexasSP's Avatar
09.12.2009, 11:19 PM
I don't think CC cares in the long run because my understanding is that since it is branded as HPI components that HPI handles all the servicing on them.
www.cubicle101.com
simplechamp
simplechamp's Avatar
09.13.2009, 04:11 AM
I think if you talked to an HPI rep they would be very careful in answering questions about this "top speed, recommended gear" subject. I remember seeing a different thread (possibly on another forum) where someone was calling out HPI on some claims about the Savage Flux (62mph, can or can't use NiMH, etc.). They posted the response from an HPI rep and it pretty much boiled down to "We are just showing what can be done and what equipment is needed, we are not saying this is a good idea or that it is covered under warranty if you wreck your vehicle and/or components."
I would imagine they would say the same for this situation.
Slowkrawl
High-Voltage Fetish
Slowkrawl's Avatar
11.06.2009, 09:28 PM
That was freeze, he posted it on a few different forums.
It's too bad that not everyone has access to this site or some other form of information other than "what the box said" because HPI is out to make money.
