What CF sheet to use for 1/8 buggy chassis????
whitrzac
Can't catch this...
whitrzac's Avatar
What CF sheet to use for 1/8 buggy chassis???? - 09.13.2009, 11:11 PM
looking around there are soooooo many diffrent styles/weaves/BS floating around, I confused
doesn't need to be super cheap, but I want 2 chassis for <$150
I found this on ebay....
http://cgi.ebay.com/Red-Carbon-Fiber...4.c0.m14.l1262
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
09.13.2009, 11:59 PM
If you can get 2 chassis out of the 12x24 size then go for the 4.4mm stuff. The 3.5mm *might* be too flexible without an upper deck. Seems like a decent product and the seller has an awesome rating. Not a bad price, either.
Rivermaxx
09.14.2009, 01:00 AM
I would get thicker stuff also. I made a t-maxx chassis out of 3mm and it flex quite a bit. Boy was it lite though.
rchippie
rchippie's Avatar
09.14.2009, 10:58 AM
Is that CF panel bi-directional weave or quasi-isotropic weave ?. The quasi-isotropic is a much stronger panel & is the strongest you can get ( to my knowledge) . Most rc cars touring offroad & pan cars are made of bi directional CF . Because dont need the stiffness of a quasi-isotropic panel .
REAL MEN RUN BRUSHLESS
whitrzac
Can't catch this...
whitrzac's Avatar
09.14.2009, 11:05 AM
its ebay CF....
I see that the "dragon plate" cf is quasi-isotropic but there has to be something cheaper out there...
rchippie
rchippie's Avatar
09.14.2009, 11:10 AM
Originally Posted by whitrzac View Post
its ebay CF....
Cheap CF is cheap for a reason . Quality Cf is not cheap . A member here i cant remember his name but will try to find out . He had a quality CF panel made by DA graphite . I belive this is the gentleman i was refuring to .
http://www.rc-monster.com/forum/showthread.php?t=21171
Rivermaxx
09.14.2009, 11:12 AM
Have you thought of using titanium? Its not as light as cf or aluminum but if its milled properly can be as light and way stronger. Aircraft use the stuff for a reason in their airframes.
rchippie
rchippie's Avatar
09.14.2009, 11:18 AM
I belive a titanium panel would cost alot more than a CF panel .
whitrzac
Can't catch this...
whitrzac's Avatar
09.14.2009, 12:26 PM
any reputable online sites I should be looking at??
pb4ugo
09.15.2009, 07:47 AM
DA Graphite does make quasi-iso laid-up panels. Been using their stuff for 25 years and couldn't recommend it more.
It is more expensive than that stuff you linked. You can also find them on e-bay under user name graphite-gurl. That's his wife selling his panels.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
09.15.2009, 12:24 PM
Sierra Composites (I recently bought some CF angle from them, good quality)
http://www.sierracomposites.com/category-s/24.htm
Dragon Plate
http://www.dragonplate.com/ecart/categories.asp?cID=75
whitrzac
Can't catch this...
whitrzac's Avatar
09.15.2009, 12:35 PM
Dragon Plate
looks like dragon plate it is then...
just to make sure, I can put the chassis kickup in buy heating it with a heat gun and bending it, right?
pb4ugo
09.15.2009, 01:24 PM
While a few on this forum have had luck with that, any composites manufacturer will tell you no and that it has to be molded in. The set epoxy is not a thermoformable material.
whitrzac
Can't catch this...
whitrzac's Avatar
09.15.2009, 01:25 PM
how hard is it to "make" your own CF sheets by using CF fabric??
rchippie
rchippie's Avatar
09.15.2009, 01:46 PM
It would be cheaper to buy the sheet all ready made . Plus if you dont know how do it properly. you will not have a good panel .
