2-speed 5mm bore adapter -
11.22.2009, 08:02 PM
I have a 54 tooth 32 pitch spur gear for 1st gear. Do you have a 1st gear 32
pitch pinion gear that has a 24mm diameter that will fit the 2-speed 5mm bore
adapter? If so, what is the tooth size?
I also have a 50 tooth 32 pitch spur gear for 2nd gear. I will also need a 2nd
gear 32 pitch pinion gear that will fit the 2-speed 5mm adapter that will match
the 1st gear ratio. What tooth and what diameter size of the 2nd gear will
work?
Thanks,
Alex
