What should I go with???
BigJ
What should I go with??? - 03.02.2006, 09:05 AM
I want to make my emaxx a bit more fun. I'm not looking to blow the doors off every nitro out there(just most), I just want some more power and longer run times. I don't want to spend a fortune either. What brushless esc and motor with what gearing should I go with? What kind of run time could I expect? Thanks for the help.
Dafni
Dafni's Avatar
03.02.2006, 09:16 AM
Welcome to the forum, BigJ!
A few questions:
What are your upgrades so far?
How many $$ do you want to spend? You could get a decent BL for around 300.
If only the additional runtime is your goal, you could just run your Titians with some high capacity Lipos.
DAF
Sylvester
Sylvester's Avatar
03.02.2006, 09:23 AM
Welcome BigJ! If you want somthing nice, not tooo powerfull, id go for a Fiegao 9 or 10L, on 12 or 14 cells , if you get the 10L, you could even go 16 if you want. As for a controller a 9920 would be the best for what you want, and the cheapest!
What upgrades do you already have?
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
boss 302
03.02.2006, 03:50 PM
welcome BigJ. I would say a 9xl and a 9920 for good runtimes but it all depends on how much money you want to spend and how many cells you are going to run.
coolhandcountry
coolhandcountry's Avatar
03.02.2006, 04:44 PM
What you have as upgrades would greatly influency my recommendation. What cell count you have or plan on running to. What chassis do you have now? cvds steel idlers anything?
WELCOME TO THE FORUM!!!!!
Peace!
Country
Help support the
Rc-Monster
Buy here
HotnCold
HotnCold's Avatar
03.02.2006, 05:12 PM
Welcome BigJ - as you can see by the replies to your first post - there are quite a bit of knowledgeable people on these forums that will definately point you in the right direction......Once again Welcome,....
Hows that "Hope and Change" working out for Ya???
BigJ
03.02.2006, 05:41 PM
Man, thanks for all the replies, on most forums I'm luck to get one reply. The Maxx is stock, but perfect condition. I'm thinkin' the 9920 and 9L are the way for me to go. I'll probably run it on 12 - 16 cells. 33-3800s. What drivetrain upgrades will I need to do for the truck to handle that? Thanks again.
coolhandcountry
03.02.2006, 06:44 PM
I would go with steel idlers for the trans. The stock sliders will need to be replaced with cvds for wheels and center. For 16 cells The 9L is going to get hot. I find the xl motors has less problem with this. The 8xl is a great motor. It would give you good torque and speed. Works well on 12 -16 cells to. It would take more if you choose.
Peace!
Country
Help support the
Rc-Monster
Buy here
Dafni
Dafni's Avatar
03.03.2006, 02:26 AM
I would also suggest an XL!
7XL if you're after speed, 9XL if you are after runtime. 8XL for something in between.
I have 7XL and an 8XL, and run them on 14 cells. I would suggest the 8XL to you. Can't go wrong.
And yeah, Mikes steel idlers are a good insurance for your tranny.
Driveshafts, if you can afford, otherwise you'll be waiting for replacements in no time. (BL power is just too tempting to always ease into throttle)
boss 302
03.03.2006, 06:57 AM
ease into the throttle... Whats that mean ive certainly never done that
You will definately need cvds the stock ones wont last for much more than a run or two
Dafni
Dafni's Avatar
03.03.2006, 07:27 AM
Means one can drive it like it's not just an On/Off switch ;)
joostin420
03.03.2006, 07:55 AM
i have an 8L in my TXT-1 and it rips on 14.4v, but it does pull a lot of amps - definately always need a fan on the controller and motor.
i would like to try an 8XL, but i really like the higher rpm's of the 8L :027:
justin
Dafni
Dafni's Avatar
03.03.2006, 08:04 AM
Justin, in this case, get a liwer wind XL. Maybe a 7XL. It rips on 14.4V!
joostin420
03.03.2006, 08:36 AM
the thing is that the 7xl is still almost 800rpm/v lower than the 8L :002:
32458rpm @ 14.4v for the 7XL versus 43474rpm @ 14.4v for the 8L
justin
Dafni
Dafni's Avatar
03.03.2006, 08:41 AM
True, but you can gear it different.
There's still a 6XL, too. With 2501rpm/V under load.
