12.20.2009, 08:05 PM
The takes approximately the same amount of power to make the same vehicle go the same speed. So take that power as a constant, and P=VI (Power = Voltage x Current), so if voltage goes up, current goes down. With less current consumption comes more runtime and less heat because current generates heat. That's the simple way to understand it.
Is it worth the weight difference?...the weight between the packs probably isn't huge so probably yes. If the higher voltage pack is double the weight and the lower voltage is already heavy, than that may be a toss up as when vehicle weight goes up, the power needed to push it to the same speed goes up also.
In general though, the weight differences between lower voltage and higher voltage packs isn't that big.
