Ok guys so im finally going for it i already ripped all the nitro stuff off my CRT and cleaned to EXTREMELY WELL ud never think it was ever used for nitro. Took about a hour to get all that crap nitro oil off the car but it was well worth it. As far as set up goes ill be useing a medusa 5900KV motor with a MM esc and 3S 35C rating battery. I already got all the electronics and i just need to order the parts to convert over ill be placing a order for everything i need tomorrow. I already have the RCM 17MM hubs so....so far so good. As you can see i removed the center diff a long time ago to get the gear ratio higher when i was running nitro. The set up worked so well i plan on using it on my brushless set up as well. I plan on starting with 18/40 gearing i hope this will be a fast little truck.
