Brakes locking up
mamba max1
mamba max1's Avatar
Brakes locking up - 08.17.2010, 12:41 PM
Hey guys,
I have an E-Revo running 6s, MMM esc, and the castle 1518 1Y 1800kv motor. When I drove the setup for the first time, the brakes were waaay too touchy. Any brake input would cause the truck to flip forwards on the ground. I thought no big deal, I'll just adjust them on castle link. Well after experimenting with several brake settings, they are now set to 0%. Unfortunately, they are still plenty strong enough to cause the truck to flip with very very little brake input.
Any ideas on what I can/should do?
Thanks!
vader2728
E-Maxx Breaker
vader2728's Avatar
08.17.2010, 12:48 PM
Maybe change the brake curve to ramp up more slowly?
So that's what all the fuss was about...
08.17.2010, 01:31 PM
Re_load the firmware and reset the end points on tx and recalibrate esc
08.17.2010, 05:24 PM
Make sure the throttle is set for 'forwards-brake-reverse w/lockout'. Kinda sounds like you have it in 'forwards-brake-reverse without delay' mode that sends it into reverse before its even come to a complete stop..
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
08.17.2010, 05:54 PM
Something is def wrong! If brakes are set to 0 then you wouldn't stop at all, that's the setting people use when running mechanical brakes on a 1/8 conversion. Are you sure your adjusting the brake strength and not the drag brakes? Otherwise I would agree that reloading the firmware is your best option and second is the reverse lockout
mamba max1
mamba max1's Avatar
08.17.2010, 06:04 PM
I have tried adjusting the brake curve without any success.
I'll try re-loading the firmware and re-calibrating it. I'll also check and see what kind of reverse I'm using. Thanks for the help!
revo guy
08.17.2010, 06:07 PM
when you give the truck throttle to move foreward does the green light on the esc flash? If the red one flashes reverse your throttle trim and swap any 2 motor wires
mamba max1
mamba max1's Avatar
08.17.2010, 07:49 PM
Well, I figured the problem out. Quite silly of me actually. I had the brakes/reverse set on the crawler mode. This explains the harsh brakes, the truck would just go straight into reverse. I never realized that it was going into reverse because by the time I tried to brake, the truck was busy flipping end over end.
