The S.O.B.
Big House
Big House's Avatar
The S.O.B. - 05.25.2010, 09:05 PM
I was challenged to build a one off RC-18 and in typical Carbon Fiber monster fashion, I built something short of a mini monster. Using a roller off ebay, i starting building the Son of beast. A couple of months and a few new parts, I finished the little monster. Here are a few pics.
Name:	S.O.B. lay up.JPG
ID:	8918   Click image for larger version
Name:	The build-up.JPG
ID:	8919   Click image for larger version
Name:	The finished roller.JPG
Name:	The front.JPG
The S.O.B. bench test
Big House
Big House's Avatar
The S.O.B. bench test - 05.25.2010, 09:12 PM
Here is the bench test video...
http://www.youtube.com/watch?v=PvLcO-5UZCg
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
05.25.2010, 10:55 PM
Looks like you did a nice job on the chassis, the video however was pretty boring. What BL combo will you be installing and what voltage ? Look forward to seeing more.
brian015
brian015's Avatar
05.26.2010, 11:51 AM
You were expecting an exciting bench test video? Maybe if it jumped off the stand and knocked everything off the bench and small children ran away screaming in terror...
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
05.26.2010, 12:45 PM
EACTLY !
You forgot the dog running away w/the tail between the legs and the wife yelling in the background.
Sorry to sound like dick, was expecting the see the tires like pizza cutters or something of intrest ? Maybe my expectations are to high ? Sorry.
05.26.2010, 01:05 PM
Well, it does only have a brushed esc & motor afterall...
When you cranked it up to full throttle though it sounds feisty, I bet it'll fly across a nice flat carpark pretty quickly...
Ballooning tires...
Big House
Big House's Avatar
Ballooning tires... - 05.26.2010, 07:01 PM
I don't get into rubber tires...they are there for the preliminary tests. Foams will be the wheels of choice. The future plan is to run a Castle Sidewinder 5700 system. No to low heat and speed as well as power. Fun all the way around. A custom top will finish the rig.
snellemin
2 KiloWatt RACER
snellemin's Avatar
05.26.2010, 07:07 PM
Looks nice man. Carbon and metal always look sexy to me.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
Need cheap brushless for the S.O.B.
Big House
Big House's Avatar
Need cheap brushless for the S.O.B. - 08.31.2010, 09:45 PM
I was initially my plans to run a 5700 in my little beastie but after further thought...for a car that weights hardly 2lbs...a Mamba 5700 on 2s would be over kill. What I need is a inexpensive brushless setup for my 1/18.
CF Ofna DM-1 Pro CC1717
CF Sportswerks Mayhem ST
CF Losi LST2
Semi Pro
Semi Pro's Avatar
08.31.2010, 11:06 PM
this is monster, if its not over kill then put it on another forum
how about a 1509 with 6cell lipo thats shout be enuff for a 2lb truck
scarletboa
scarletboa's Avatar
09.01.2010, 12:20 AM
he can do better than that. go for a MMM 2200kv combo. you could gear it for 200mph and still get stone cold temps.....as long as the drivetrain holds up maybe you can set the torque control to .1 or .2
