MMP able to handle this Motor? -
01.02.2011, 01:59 PM
Hi,
I just ordered a 6-Pole 5000kV motor (1000 Watts) for my Slash 4x4.
Now I started wondering if the MMP will be able to handle this motor on 2S LiPo?
Especially the 6-Pole part of it.
The amps doesn't depend of the motor but of the setup (ratio, weight of the vehicle, etc...). I would wonder about the commutation speed required to run a 6 poles 5000Kv motor. The mmp can run a 4 pôles 5700Kv (new Castle 4 poles motors for 1/10scale), so I don't know if it can run a 6 poles 5000Kv motor. Just wait another reply of Castle guys.
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
Last weekend I had my first run with a MMPro in a Slash 4x4 with a 6 pole brushless motor (1530kv @5s). I have it setup for the same speed as a stock Slash 4x4 on 2s. After 30minutes of bashing the motor reached 44c and the MMPro was 15c.
The setup needs some fine tuning in timing. The manufacturer recommendend 5 degrees timing, but on forums I've read that 20-25degrees timing is best. So that will be my next attempt.
Hmmm looks like you got the same motor, i have, just with different "T's"
Sounds like a 10T one
Slash on 5S ? Thats a lot power. how much mA do your batteries have ?
I have 3S 6500mA and get almost 25min runtime Indoor so around 73Wh
A 4000mAh on 5S would be around the same (74Wh)
yep, mine is a 10. I'm running a 5s3000mah 40c zippy.
So, if you're running the same motor, do you also get a minor glitch a very low speeds? When I 'crawl' along it suddenly boosts forward a bit. This only happens with very little throttle.
No cogging
I can crawl' are real low speed but i have seen the "sudden boost" some time as well
But on the CC2200 Motor, i have seen the same.
I use 10 degrees timing currently and no Punch Control
Low Start Power
But over all MMP and the Motor are a great combination.
I'm more than happy
100% undergeared ! Those Motors don't care much about gearing
We had a test with the /7 on MMP in a SC8 compared to the CC2200 Motor (same KV)
The /7 does take 15-19 pinon and does not care ;-)
On higher timing, you will see less temps !
BTW the magnets can handle up to 180 degrees ! on all of them
10 degrees was just a test, i will go back to 18-20. But without Sensor, the MMP can't do more than 20.
I wish a 2240/10 would come around my house... compare 3S to 6S
Castle, maybe this would be a welcome change for the firmware, to allow maybe 25 degrees of timing, without sensor
