1) Tweak the brake curve itself on the castlelink so that is more gradual/ progressively stronger as you squeeze the brake harder, rather than being linear which is default.
2) Pump the brakes vs squeezing them as such, to simulate ABS- this works really well for me actually ( I either ended up with front flips or broken ankles no matter how I set the brakes in the early days, now I have them at ~40% and pumping them helps reduce endos greatly ).
Thanks for the tip. I adjusted the brake curve and it works awesome now. I may even be able to turn it up some. I can grab full brakes without worrying about flipping over, but it does take about 15 feet to stop from ~50mph.
15 feet is nothing for something that heavy, traveling that fast, takes me about that far to slow down my Gmaxx ( doesn't help that I'm a poor driver but all the same ).
