12.06.2011, 08:10 PM
GT1 bodies and many other "standard" length 1/8 onroad bodies will fit the Losi. If you want to run GT2 bodies you could use a truggy chassis, check the specs though as the 2.0 is longer than the 1.0 and I'm not sure which you'd need. As for making it better for onroad use, you should start by limiting suspension travel. Adjusting the downtravel limiters built into the a-arms will lower the car and obviously limit downtravel. You might also want to add some fuel tubing to the shock shafts, between the ends and the shock body, to limit up travel a little bit. But you'd only do that if you have alot of up travel left after the chassis is bottomed out.
