Xray XT8-E '09
SavageCanadian
SavageCanadian's Avatar
Xray XT8-E '09 - 09.27.2010, 03:56 PM
Picked up this '09 XT8 a couple of months ago knowing I wanted to run a electric truggy for next year and since my Xray T3 works so well on the carpet I knew xray was the way to go for the dirt as well. Just got the conversion a couple of days ago, so it was time to convert her over. The conversion is really well built, everything went together smoothly, awesome job Mike I also went for the optional receiver box which cleans all the electronics up nicely. Im going to run a Tekin RX8 with the 2250 truggy motor on 4s. I picked up a 16t pinion but I have no clue of thats going to work well or not, any suggestions? The body is the Bulldog for the MBX6T. Anyways here are some pics, and yes I know I need to lower the rear body mounts
  Send a message via MSN to SavageCanadian
Nard Cox
n00b
09.27.2010, 05:31 PM
I love that Bulldog body!!
The car looks clean, you'll enjoy running it ;)
76Bentley
09.29.2010, 03:24 PM
Man that thing looks awesome, I think the body looks fine as it. Great Job!
SavageCanadian
09.30.2010, 10:23 PM
Thanks guys, the motor system should be here early next week so I can get it dialed in before the season comes to a close.
Xray XT8-E '09 Spec - Tekin RX8/ 2250/ RCM Conversion/ Gens Ace 4s 5000 40c
10.01.2010, 06:56 PM
very nice indeed. Mike does make THE best conversion kits around...often duplicated but never replicated.
SavageCanadian
10.05.2010, 05:41 PM
Well I got the motor system mounted up and programmed. Hopefully the 16T pinion is ok for the first test. I also lowered the rear of the body and it looks even better now Just need to put it on the setup station and then get it on the track
feistyacorn
feistyacorn's Avatar
10.05.2010, 05:59 PM
Nice Looking truck! Gotta love XRAY! I am running 5s with a 1550kv motor, I am geared 14/46 and am still messing around with that new timing feature in the software. I dont really think there is an exact setup for everyone, but you might want to give the speed calc a try. http://scriptasylum.com/rc_speed/
SavageCanadian
10.06.2010, 06:29 PM
Thanks guys, do you know any plastic mod1 spurs that fit the xray center diff?
feistyacorn
10.07.2010, 11:54 AM
Do yourself a favor and pickup a Slipperential. Mike offers delrin gears and it will save your entire drive system. A friend’s Losi without Slipperential is looking at new drive pins after one season of racing.
SavageCanadian
10.08.2010, 06:50 PM
Does the Slipperential really make that much of a difference?
Semi Pro
Semi Pro's Avatar
10.10.2010, 09:41 PM
yes it does, it takes the shock out of the drive train when landing junps while still on the throtle.
if mike made one that i could keep my torsion diff i would run one for sure
feistyacorn
10.11.2010, 10:34 AM
It's really a nice tuning option and it helps save the entire drive system. I run one in my XT8 and Gorillamaxx. Just make sure you get the real deal from RC-Monster and not the cheap fake one.
SavageCanadian
10.16.2010, 06:55 PM
Well I took it out for its first test run today and it did really well. The chassis flies nice and neutral. Im defiantly impressed and I have yet to put it on the setup station. I can defiantly see were the slipperental would be nice to help smooth out the power. I will have to pick on up over the winter for next year.
SavageCanadian
03.05.2011, 03:56 PM
Just ordered the slipperential finally, anything setup wise with it I should know?
feistyacorn
03.07.2011, 11:58 AM
I guess it probably depends on what the track condition is like. I am running 5k-7k-3k for diff oil in my setup (similar to yours). Did you get the steel gear or the delrin gear?
