2 VX G3 5400mah 2s MM2200KV XTM big block chassis 3906 trany locked in 2nd ue 8 diffs ue shocks mip cvds rpm arms & RPM Axle Carriers ue rear dog bone ofna dom front dog bone hc titanium skid
I was gonna ask the same thing- every guys that has done the LST cvd upgrade has had to run odd-sized bearing or shim them to make them fit correctly- did you have to do anything special as such?
big hole is 24.5mm I used two 15x24 and alum tape. small end is 15mm now 5/8 so 16x8mm fits good and tight I'll try to post some better pic of how I did it later
