hacker 9xl 8s lipo mgm 16024 speed?
luvsrc
RC-MONSTER BRUSHLESS FANATIC
luvsrc's Avatar
hacker 9xl 8s lipo mgm 16024 speed? - 06.04.2006, 12:13 PM
i was wandering what kind of speed will i get with this set up all drivetrains have been beefed up, has ultramaxxed gears on it as well, will mgm 16024 handle this much power? thanks
coolhandcountry
coolhandcountry's Avatar
06.04.2006, 01:49 PM
If you plan to drive it alot. I am not sure if the motor will survive. It may or will over heat if long run. I ran a 9xl on20 cells. It was warming up nicely. The esc should survive no problem.
luvsrc
luvsrc's Avatar
06.04.2006, 02:02 PM
will this set up easily reach 50mph? or even 60 mph? i'm probably just gonna run it for speedruns only not offroad but not to bash it around for it will be too much for the system, i'm thinking of buying the apache 4s lipos mike is selling will that be anough discharge amps for that set up? thanks
Serum
Serum's Avatar
06.04.2006, 03:20 PM
Too hot imo.
50000 rpm. Go figure.
You need to get into the 35000 rpm range.
luvsrc
luvsrc's Avatar
06.04.2006, 04:24 PM
will a wanderer 12 xl on 8s lipo do the trick? for bashing capable (depends on gearing) 50-60-mph range? will it outperform any nitro high powered monster trucks?with my hacker c50 maxx system with 4s lipo, can reach speed of 45mph (depends on gearing), on 5s will reach 50 mph ? it might push the c50 maxx motor to it's limits, since 4s lipo fully charge capable of giving 16.4 volts
Serum
Serum's Avatar
06.04.2006, 04:31 PM
Yeah it will pull the pants of a fast nitro truck.
8S lipo..
With the right lipo's you can do a good 4000 watts of power peaks..
50-60 mph is doable. Take a lightweight truck and make it fly.. :)
