Originally Posted by nastety92
I am looking to put a brushless setup in my Stampede and E-Maxx. I'm looking for a brushless setup that I will not have to change many differential or internal parts. More or less I'm looking for a slight increase in power and performance over stock but thats not going to be breaking parts while driving normally. Which combo would be the best for my needs. Thank you for any and all help,
Nick
If you are looking for a brushless system that you don't need to change a lot of parts, I would suggest Novak. they're 4300 system would be perfect for the stampede and geared right is as fast as any brushed sport motor (speed gems like) you'd put in there. I seen one run its nice, i got a 5800 in a t4, but it might not be good unless you get an alumnium idler gear.
To the Emaxx, if you want to get away without much mods, I would suggest a Novak HV-maxx brushless system. Its a little weaker than all the other options but i run one in a Gorilla Revo conversion with a stock idler and no problems, not sure how the diffs will be with it, I never run my E with a brushless.
These systems may be more expensive (slightly) than some of the suggestions already given but they can require more in mods than i think you want. The only thing i did with my revo to handle the power is get a Robinson slipper kit with a 72 tooth Plastic gear and run a 12 tooth pinion.
Which ever setup you choose, there is not a loser in the bunch, good luck and have fun
