My brushless HPI Nitro MT Project
GeeReg
GeeReg's Avatar
Cool My brushless HPI Nitro MT Project - 05.22.2006, 04:49 PM
Well my first real brushless project has begun with me winning a used HPI MT roller with radio for $60. :eek: My only BL experience is with an RC10T2 with a Novak SS5800. I liked the power but needed more and needed it to be 4WD. I was thinking a 1/8 buggy, but figured a 1/10 would be cheaper and easier. I saw Camel's MT18SS and liked it, but didn't want to spend that much, so I picked up this MT.
I'm thinking a Feigao 380c 6L or 8S (8T here at RCM?) with a Warrior 9920 and 8 cells. My max is 8 cells due to my charger limit, and I'd rather not split it into 2 packs as this makes charging very long. Which is the better choice, the 6L or 8S? What size pinion should I look at? Any other recommendations for a controller? This will be strictly for bashing.
I'll update this as it progresses...wish me luck! :dft003:
squeeforever
squeeforever's Avatar
05.22.2006, 08:10 PM
I would go for a 8S since it will have more torque and shouldnt heat up as much.
GeeReg
GeeReg's Avatar
05.22.2006, 08:31 PM
I thought the L series would have more torque?
*edit* Or do you mean that a 6 turn L will have less torque than an 8 turn S? I can't find any numbers from Feigao for torque.
MetalMan
MetalMan's Avatar
05.22.2006, 08:52 PM
The 8s won't necessarily have more torque, since it has to do with the number of amps the motors will pull. Unfortunately, Feigao doesn't publish the kt ratings (torque constants) for their motors, so we can't tell which motor will put out the most torque at the same number of amps.
It's relatively tough to decide without actual numbers which motor has the highest kt. The 380C 6L is longer, but the 540 8s is larger in diameter. They have similar kv ratings (by several hundred). If it were my decision, I would pick the 380C 6L. The can of this motor is a heatsink, so it can dissiapate heat well, and it has removable endbells that won't pop off like the 8s's endbells will. This also makes motor maintenance (bearing maintenance) easier. Besides those things, the 380C 6L is less expensive.
GeeReg
GeeReg's Avatar
05.22.2006, 09:09 PM
Thanks for the reply. I actually meant the 380c 8S, not the 540. The 6L pulls 69 amps and the 8S 52 if that helps.
squeeforever
05.22.2006, 10:28 PM
Actually, they call them a 8T instead of a S. But yes, out of those 2 I would also choose the 6L.
Metalman, in theory, wouldn't the 540 8S have more torque than a 380C 6L?
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
05.22.2006, 11:47 PM
kt in oz/inch/amp is 1352/kv. Kt is always proportional to kv. So a higher kv motor will always have less kt. The total torque depends on the number of amps times the kt. In theory, a 540s will have slightly more torque than a 380c 6l. They both will draw about the same amount of amps, but the 8s having ~4400 kv verses the 6l having 4900 kv will have slightly more kt. Once you gear the 8s higher to compensate, both motors should theoretically have the same power output, although the 6l spools up faster in real life.
Area 52 Ranch Raceway
T.R.C.R.
GeeReg
GeeReg's Avatar
05.23.2006, 07:50 AM
Hmm, good info. I'll probably go with the 6L. Hell they're cheap enough now that I can just buy another one to play with if I want to.
GeeReg
GeeReg's Avatar
06.04.2006, 06:04 PM
Well I went with the 6L and Mtroniks Truck. Here's a few pics:
How I got it. It looked cleaner it person:
Cleaned up:
First attempt at a mount….lol
That’s better:
Not the sturdiest thing in the world but we’ll see how it holds up. I just bent a stock mount for a Tamiya MaxClimber.
And the modified radio/servo tray:
SpEEdyBL
SpEEdyBL's Avatar
06.04.2006, 08:57 PM
Nice! Let us know how it runs.
T.R.C.R.
cart213
cart213's Avatar
06.05.2006, 09:36 AM
You may get a lot of flex from that motor mount, which will affect the gear mesh. The mount may need more than two screws holding it to the chassis. Check out this thread to see my motor mount. It's overkill really, but there sure isn't any flex.
http://www.rc-monster.com/forum/show...&highlight=mt2
GeeReg
GeeReg's Avatar
06.05.2006, 11:22 AM
Yeah I saw your MT2 thread. I know the mount isn't great, it's temporary until it causes a problem. I liked cold fusion's but I didn't like people sending money and not having a mount months later. I don't know anyone with a machine shop and e-machine wants $60-$80 and a month to make one so I'm kindof stuck at the moment.
cart213
cart213's Avatar
06.05.2006, 01:30 PM
Yeah, I'm lucky that I've got access to a machine shop at work (plus a lipo charger). :)
squeeforever
06.05.2006, 06:17 PM
I think adding a brace would make it strong enough. I would use something like a Hyper 7 rear chassis brace.
GeeReg
GeeReg's Avatar
06.05.2006, 06:59 PM
I was actually thinking about that or maybe something going to the spur gear housing. I don't do 20 ft backflips like a lot of people here that I've seen so it may just be ok, but I'll probably end up with a brace of some sort.
*edited* I DON'T do backflips lol
RC10T2 - Novak SS5800 - 7-cell GP3700
HPI RS4 Nitro MT - Mamba Max 5700 - 2S 5500mah Lipo
MRC Thunder King - Mtroniks Truck ESC + Feigao 9L - 3S 6000mah Lipo
