warrior 9920 not working -
07.17.2006, 07:25 PM
i got a BK Electronics Wanderer "XL" Brushless Motor anda warrior 9920. k i got it all hooked up followed the instructions, but i am trying to program it, but i am not getting any beeps or anything
07.17.2006, 08:34 PM
Did you pull the red jumper? Here, this might help.
07.17.2006, 08:35 PM
Pull the red jumper out, program and plug it back in. did you pull the black jumper?
07.17.2006, 09:33 PM
i pulled the red jumper and the black one, and tryied with the red one out and the black one in, and black one outt and red one in
mod emaxx
07.17.2006, 09:35 PM
The black jumper is for the internal bec. Jumper on=internal bec enabled and jumper off=not using internal bec. One other thing to check is the 2 pins that are sticking out after you remove the red jumper. Make sure they are not touching each other or something metal. Hope this helps some. I would also cheack all the connectionson the motor and esc
So many toys and so little time
07.17.2006, 09:37 PM
Red jumper is for programming.
Black is the BEC. Pull the black one out to disable the BEC if you are using 12 cells or more, have more than one servo, are using a receiver battery pack, or an external BEC. It shouldn't have anything to do with programming.
If you are having trouble teaching the ESC your transmitter, make sure your EPA is set to default. Also, try reversing your throttle on the transmitter.
07.17.2006, 10:02 PM
the pins are fine, i am using a reciever pack i will check the transmitter thing
07.18.2006, 02:19 AM
if you use a rx pack, don't disconnect the red wire from the "esc to rx" connector, just unplug the red caliper on the controler circuit...
07.18.2006, 01:46 PM
personally, pulling the red wire causes confusion for me, pulling the jumpers are easier to understand, also, follow the sticky(i think squee sent it to you) word by word, it puts everything in lamans terms!
07.18.2006, 04:27 PM
My bet is on reversed throttle on your radio.
07.18.2006, 04:38 PM
If it won't program correctly, that would be my guess too. I only had that problem with my JR radio though.
07.18.2006, 05:59 PM
i have to try the reverse thing
07.27.2006, 03:12 AM
okay tyried the reverse thing did'nt work i will try a differnet reciever
07.27.2006, 09:21 AM
How old is your motor? My guess the controller is shot, and if a different reciever does not work, then check your servo's
07.27.2006, 02:36 PM
brand new never used
