stock lightning diffs question
fagzz
stock lightning diffs question - 08.11.2006, 05:57 AM
Hi guys, I just received a pair of new lightning diffs, and i wondered if it was normal that they are pretty difficult to turn with hands... I imagine that it's due to the oil diff that is cold... Am i right?
Or do I have to open the diff cups to put a lighter diff oil on it?
Can someone help me please?
All thanks,
Fab.
HotnCold
HotnCold's Avatar
08.11.2006, 07:13 AM
just leave them alone - unless your going to change diff oil for a reason - a little tight is better than a little loose - they will break in - good luck...
Hows that "Hope and Change" working out for Ya???
Serum
Serum's Avatar
08.11.2006, 07:57 AM
The diffoil should be silicone, which isn't affected much by temperature.
fagzz
08.11.2006, 10:12 AM
ok thanks, my old diffs were completely untightened, cause i run 80% asphalt and pavement... i will see what will be the behaviour of my car...
and yes if it's some silicon oil it can not be affected by temp... that's right Serum, I forgot that fact...
again i will let you know how it runs... i build a new E-maxx actually, from my old one that i shew here 2 weeks ago...
fagzz
08.11.2006, 11:43 AM
ok i mounted the diffs into the hybrid bulks, but i discovered that i needed to change the lateral cups??? My cvd's are 4 or 5mm too short for the lightning diff cups...
I have the MIP cups that come with the wide shiny cvd's, and i wonder how to make them fit these diffs...
any advise???
fagzz
08.12.2006, 01:36 PM
please i need help to finish my car, that's the only thing that make me crasy... i run wide RPM arms and MIP wide cvd... what's wrong with my config??? What diff cups to use on the lightning diffs???
thanks in advance...
Fab.
squeeforever
squeeforever's Avatar
08.12.2006, 01:41 PM
Use the ones you have. Scew in the pillow balls as much as you can. Got a picture?
Serum
Serum's Avatar
08.12.2006, 01:52 PM
either MIP or UE cvd's should work. Perhaps your pivotballs are out too far, like Squee mentioned.
stay cool bro.. :p
fagzz
08.13.2006, 08:46 AM
here is a pic of my problem:
in that pic my pivotballs are tightened at max... the cups seem to bee too short... where does the length problem come from???? that makes me crasy... 200$ of parts and it doesn't work at the end... :(
i didn't found any idea about how to use my MIP cups on these diffs... Lightning cups don't have any screw...
Serum
Serum's Avatar
08.13.2006, 09:02 AM
You are sure those are MIP cvd's? they don't use a boot like that. The MIP shaft itself is the boot.
I doubt if these are MIP cvd's.
However, there is a way you can make it work;
cut off a piece of your RPM arms, and drill the holes deeper if needed. Or buy UE or MIP cvd's
fagzz
08.13.2006, 10:05 AM
those are not MIP but they are the same length... pic was taken before i tried to mount the MIP ones...
Serum, you're right, i will try to short my arms about 3/4mm each...
squeeforever
08.13.2006, 10:56 AM
Keep in mind, you will probably bend a CVD or 2 with RPM arms.
Serum
Serum's Avatar
08.13.2006, 12:42 PM
I never heard of an issue like this when the MIP cvd's are used?
coolhandcountry
coolhandcountry's Avatar
08.13.2006, 02:39 PM
They look more like a rd logic which is a touch shorter than mip or ue. The cups makes up the difference.
Peace!
Country
Help support the
Rc-Monster
Buy here
fagzz
08.13.2006, 03:11 PM
yes you all right, the MIP cvd's are at the right legth... i made a mistake in measuring... shame on me again, it's really hard to enter the race word... :(
