Li-Po cut off product suggestions
brewerj
Li-Po cut off product suggestions - 09.08.2006, 03:14 PM
I am running 2 Kokam Li-Po 4800 packs in my E-maxx and always stop before I know where the cut off is, but I wanted to get some cut off circuts before I go brushless and I wanted to know if anyone has suggestions. I am relatavily new and would need something dummy proof. Thanks!
OldSoldier
E-ReVVo/SoldierMaxx
OldSoldier's Avatar
09.08.2006, 03:43 PM
This is the only one I know about. I've never used one, but talk to the guys at MaxAmps if the guys on this forum don't have a better answer.
Low Voltage Cutoff for 1-4S Lipoly Packs $39.99
Cellpro 1-4S Discharge Protection Module (DPM) plugs in-line with any ESC control cable going to the receiver throttle channel and also plugs into to the Cellpro battery pack node connector. It monitors each cell during flight and cuts off the motor when the weakest cell is safely depleted.
Weight: 0.3oz (9grams)
Comes with plug to connect directly to the Hyperion type/MaxAmps standard taps
http://www.maxamps.com/index.html?la...d=38968.470081
MetalMan
MetalMan's Avatar
09.08.2006, 06:49 PM
The CellPro LVC would work... But it will require that the little extra ballancing port on both batteries be utilized, and then would need to connect to the outputs of both batteries. It would require some work, but would be doable.
Some members here use the LiSaver:
http://www.atsrcplanes.com/lisaver1.htm
It will work best if you have reverse disabled, due to the nature of it (it's made for RC airplanes).
coolhandcountry
coolhandcountry's Avatar
09.08.2006, 07:05 PM
If you going to get a brushless system. You can get one with a built in lvc.
Peace!
Country
Help support the
Rc-Monster
Buy here
jhbronx
09.21.2006, 05:34 PM
I wanted to use an automatic cut-off myself for a starter box for my gas car, but it seams like that li-saver requires the use of a receiver and a speedcontroller. I need a dumber system, just to go between the battery and motor and cut-off the discharge when the voltage drops.
Serum
Serum's Avatar
09.22.2006, 01:20 AM
@jhbronx;
get a warning led, that starts blinking when the voltage drops.
@brewerj;
here is the device i ordered;
http://www.dimensionengineering.com/LipoShield.htm
