Toughest MT, for 2280..
aqwut
Brushless Heavy Weight....
aqwut's Avatar
Toughest MT, for 2280.. - 09.18.2006, 09:04 AM
What's up..!!?!!
I've decided not to use the 2280 on an E-maxx anymore.... I can't decided which monster truck is the best choice for the 2280... I was thinking of either a savage or an LST/LST2 .... So I need you guyz' help on deciding.... I'm leaning towards the LST since I have a nitro one laying around... But I was thinking maybe a Savage is tougher?... Would there be room to fit this on a savage?.. Are the diffs on the savage and the LST comparable to the 7.5 8 Spyder diffs on my E-maxx in strength?... THanks.. any input will be appreciated and I will make out a check for every reply... thanks.. hahaah j/k
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
nl12
nl12's Avatar
09.18.2006, 10:18 AM
I would put it in a 1/5 FG monster truck and run it on 8s2p.
aqwut
aqwut's Avatar
09.18.2006, 10:33 AM
I was thinking of that too.... but then I'll have to fork out a grand for that thing...and the parts/arms.. doesn't look too tough.. only 2WD....
HotnCold
HotnCold's Avatar
09.18.2006, 11:18 AM
those fg's are pretty tough -i had one - they take quite a beating - and the 2wd isnt that big of a deal with the weight. They are working on releasing a 4wd conversion for the fg (might even be out by now) - that will be a sight to see....
Hows that "Hope and Change" working out for Ya???
cart213
cart213's Avatar
09.18.2006, 11:27 AM
How about an HPI Baja 5B?
Serum
Serum's Avatar
09.18.2006, 12:05 PM
In Germany they have got a 1/5th 4wd.
I would take a savage with a centerdiff to use it in. Ask Mike to make you a special pinion (wider) and use an ofna diff with two spurs mounted behind eachother.
Here is a list of things you need;
Ofna centerdiff (25 on ebay)
UE supersavage CVD's(they include the drivecups with them) (130 dollars)
Hotbodies C8019 cups (10 dollars)
Dynamite/GPM diffhousings (50 dollars)
FLM ext tvp's with centerskid(75 dollars)
and keep the rest dead stock. or use the shocktowers of twisted toyz (60dollars) with UE shocks.. (75)
shimm the diffs properly and you have got a nice machine.
aqwut
aqwut's Avatar
09.18.2006, 07:25 PM
Thanks.... I'll do some more researching... I'm just afraid of gettin' parts for that FG Marder.... It's freakin' huge..... Hey, any of you guys know about the neweramodels 1/6 Savage conversion kit?...
cemetery gates
09.18.2006, 07:45 PM
a guy that i know has one and the directions are crap!! he had to bend and modify things to get a rough fit. IMO not worth the $500 or what ever..............
aqwut
aqwut's Avatar
09.18.2006, 08:17 PM
Thanks man.... I guess it's a good bye to that.... there's some guy selling an FG Marder with front and rear disc brakes for $1500 cdn...is that worth it...
Serum
Serum's Avatar
09.19.2006, 01:21 AM
That newera 1/6th conversion is a waste imo.
coolhandcountry
coolhandcountry's Avatar
09.19.2006, 01:24 PM
If you have the lst. I would consider doing a custom chassis to fit a ofna diff.
Get the wide pinion and run two spur gears. You could go with like a carbon
fiber. I not sure how well the diffs are though. You could get the extended flm chassis to fit the motor better in it.
aqwut
aqwut's Avatar
09.19.2006, 05:24 PM
the diffs are the only thing I'm afraid of... I've had really bad luck with diffs.... Cool.. I didn't know flm had an extended chassis....
coolhandcountry
09.19.2006, 07:51 PM
Yeah. FLM has a extended chassis and combo bulks to. They both are a nice addition to the savage. Get some aluminum diff cups to go in them as well. Make it alot stronger.
aqwut
aqwut's Avatar
09.20.2006, 08:02 AM
Cool... since I have already have a nitro LST, I will use my center diff conversion for it.... and I already ordered the LST2 Diffs complete Aluminum from ebay for $25.... Well.. if the LST doesn't work out... I guess it will be the savage.. and I'll do the same as serum for the diffs....(shims)
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
09.20.2006, 08:20 AM
sounds cool, good luck and keep us posted will ya....
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
  Send a message via MSN to sjcrss
