Can I do this with my 8xl/9920?
ncalenda
Need for Speed
ncalenda's Avatar
Can I do this with my 8xl/9920? - 01.11.2007, 03:52 PM
I want to connect in a series 3 6-cell packs in a series, for 18-cell. I see the 9920 will support up to 20-cell. Will the motor hold up?
Thanks,
Nick
  Send a message via AIM to ncalenda
01.11.2007, 04:08 PM
Assuming 1.2v/cell, that will make the total rpm a little over 40k. That's a little hot if you plan on running at full speed a lot. But for brief speed runs or an easy trigger finger at the track, it should be fine. Just watch temps.
ncalenda
Need for Speed
ncalenda's Avatar
01.11.2007, 04:13 PM
YEs, 1.2v/cell.
Next question, what motor could handle this without getting too hot?
01.11.2007, 05:33 PM
Like I said, the 8XL will be good if you don't run it at that speed all the time. If you do plan to run max speed a lot, then a 9XL or 10XL would be a better choice. You generally want your motor to hit a max rpm of about 30k-35k rpm for best efficiency.
