BL Motor Mount for Stock Revo Chassis?
BigSushi
BL Motor Mount for Stock Revo Chassis? - 01.26.2007, 10:03 PM
Building out a E-Revo and failed miserably making a motor mount. Does anyone make one to mount to the stock Revo Chassis? It needs to support a Neu.
Thank you in advance!
GorillaMaxx360
GorillaMaxx360's Avatar
01.27.2007, 12:37 AM
Here is a thread with a motor mount for brushless and using the stock revo tranny and chassis.
entjoles
01.27.2007, 12:59 AM
i made my own also but plan on buying his motor mount because its so adjustable, i think he sells it alone, check out mine i built a brace underthe truck to reduce flex, very solid but no gearing options
renny
if you build it.... Then I can break it
renny's Avatar
02.04.2007, 03:55 AM
I bought a nemesis motor from fine design and it came with two alum. pipe clamp style mounts so I just set my gear gap, marked the hole locations on the stock revo chassis.The outside holes just missed the chassis so I put a small 1 3/4" X 2 1/4" X 1/8" thick piece of flat alum. right under the mounts and drilled four holes and bolted the mount from the bottom for extra support.
