slipperentials -
01.31.2007, 10:24 PM
are they ready yet. Also I believe Procharged was working on a slipper, any word on that one?
02.01.2007, 07:01 AM
Yes, check the store, under rc-monster parts, you´ll see them. Procharged has got a slipper, not a differential. Mike is currently working on a slipper-diff in one.. it should be the bomb IMO. Nice for buggies and truggies!
02.01.2007, 12:33 PM
The slipper diffs are what I was asking about, not the transmissions. Anyway, my stock emaxx slipper is shot. What are my choices and which would be the best for the stock chassis?
As far as the RC monster store, whats the deal with everthing out of stock, its been like that for a while.
thanks
02.01.2007, 12:38 PM
If you are running a stock e-maxx trans then my slipper will do you alot of good. Look for the post from the other day detailing the product & for pics (LINK BELOW). Other choices are the Robinson Racing Products slipper (I've used it with success) and the Strobe sold here at RC-M.
http://www.rc-monster.com/forum/showthread.php?t=5425
02.01.2007, 12:53 PM
Looks good, what is the size of the spur? What kind of price? I can't read the writing its to small. Thanks.
02.01.2007, 12:58 PM
Try clicking on the image and maximizing your window. It should be easily readable.
Spur choices are 48t/49t/50t/51t/52t
Price has not been set yet but will be soon. Expect $60 for the Standard Version and $85 - $90 for the PRO version.
02.01.2007, 01:00 PM
click on the picture and it will blow up for you.
02.01.2007, 01:21 PM
Yes, I can read it now. I was trying to read the one you posted in the link, that one will not maximize enough.
02.01.2007, 01:23 PM
Glad you got it! Very good info there.
Spurs -
02.01.2007, 06:44 PM
Hi
What pitch will these Spurs be? 32 or Mod?
Spurs -
02.01.2007, 06:46 PM
Hi
What pitch will these Spurs be? 32 or Mod? Also one more question , what advantage in terms of performance will these be over the RRP Dbl disc setup.. I'm assume torque control as traxxas states with their Revo and Maxx 3.3 vehicles..
Cheers
02.01.2007, 06:47 PM
Hi Kiwi. Welcome to the RC-Monster forums.
The Spur gear will be MOD-1 to match up with most brushless motor pinions.
I do not have a 32P gear available at this time but MOD1 pinions are available in 1/8", 4mm, and 5mm bores.
02.01.2007, 06:49 PM
Originally Posted by Kiwi E-Maxx
Hi
Cheers
Torque control, stronger input shaft, stronger gear to shaft attachment, better gear selection, and with the PRO model lower friction & wear, stronger spur, cooler operation.
Hi -
02.01.2007, 06:54 PM
Thanks very much,
I'm sold if there is a 1/8 bore Mod1 10 tooth Pinion. Don't think Mike sells them.
02.01.2007, 06:57 PM
Mike can get one or make one though! :)
