She's got:
FT18T with upgraded shocks, Titanium turnbuckles, Carbon strap, etc.
Mamba Competition 6800 System (w/ Fresh Motor - I mentioned before that my other motor had been to astronomical temps, this is a new one that hasn't seen much above 100)
Heat sinks on the motor
JR DS285
Digital Micro Servo (and an extra set of gears for it)
Metal Steering bellcrank and metal/stiffer servo saver "spring"
Metal Rear A-Arm Mount/Hingepin holder
MIP Super Diffs
MIP CVD's (since the dogbones bind)
Rubber Sealed Bearings Set (all bearings were replaced)
Blue Aluminum Ball Studs
Modded RPM Bumper (check the pics)
Stock tires on Wabash rims (worn to slicks - good for street though)
Dirt Hawgs on stock dish rims (nearly perfect)
Protective film on bottom of chassis (keeps screws clean and helps reduce scuffs)
Kyosho Inferno Wing mounted with 18B wing Mounts
Comes with manuals, original box, (original box to major parts like Mamba and servo), spare parts, pinions, etc. Does not come with radio system. May come with a battery depending on price (battery is a 1500mah 3S Maxamps Lipo).
She's in great condition with ~10 runs on it, if that. Dont let the scuffed up body fool you, thats just because of some pavement skids.
It will pull rollling wheelies and do spectacular burnouts/donuts.
Need money for a new project :027: (or possibly to overhaul a truck that seems like it will give out soon :007:)
PM for more information...
