need to loose weight
ncalenda
Need for Speed
ncalenda's Avatar
need to loose weight - 03.16.2007, 12:20 AM
I put my e-maxx on the scale, with the IB 7-cells, and it was over 12 lbs.
I know if I get lipos, that might make the biggest difference, but what would be second best, tires? I have the stock revo tires with revo rims.
I still have the stock tranny, but I like the low gear, I use it for tug of war with my dog :005:
I have the stock e-maxx chassis, revo titanum center axles, steal front and rear axles, etc.
  Send a message via AIM to ncalenda
squeeforever
squeeforever's Avatar
03.16.2007, 12:31 AM
Going to a 3.3 setup and losing the cvds will lower the weight. Going to a G3 chassis should lower the weight. Going with some MT tires will lower the weight. And obviously, going LiPo will lower the weight. Also, going BL will lower the weight, although I'm not sure if your running BL since you didn't specifiy.
ncalenda
Need for Speed
ncalenda's Avatar
03.16.2007, 12:52 AM
I am running brushless now, the 9920 / 8xl. What MT tires are lighter? Also, which rims?
I may consider going lipo, I just hate the initial expense.
I also have the pro-line shocks.
crazyjr
crazyjr's Avatar
03.16.2007, 12:56 AM
Almost all the proline maxx sized tires will be lower in weight
Serum
Serum's Avatar
03.16.2007, 02:22 AM
the revo tires aren't that heavy. but you should be able to shave off 3-4 oz.
can you shoot a pic of your maxx?
Finnster
KillaHurtz
Finnster's Avatar
03.16.2007, 10:49 AM
Last time I was there Proline had weights of all their tires on their website, useful info. Obviously you need to pair this up with lightweight rims. the lightest tires are the crimefighters in Mt siries (40s are heavy.) The Revo tires/rims are actually pretty good weightwise for all around tires.
Otherwise, replace any metal parts with plastic that you feel comforatble with. Lipos and a single motor also goes along way. (Edit:n/m, you have BL.) Other than that, you get into procedures whereby you start trimming away excess material.
What is your application and goal? If you're just a basher/"dog-fighter", put it on the scale and went "whoa! what a pig!" does the weight really matter? Chopping weight down can get really expensive, depending how deep you go. What's it worth to you?
ncalenda
Need for Speed
ncalenda's Avatar
03.16.2007, 12:47 PM
Here is the thread of pics I had uploaded. In the pics I had the chevron tires on becuase I use those for sand, but use 4 revo tires for all other terrain.
Would the tires shave 3 - 4 oz per tire?
ncalenda
Need for Speed
ncalenda's Avatar
03.16.2007, 01:13 PM
I bash, but I was suprised to see it weighted so much. I was thinking if it was lighter maybe it wouldn't break as much.
It would be good to have good tires, and the lipos. Looks like those two things would really make a diff.
Serum
Serum's Avatar
03.16.2007, 01:16 PM
I can't really look thru a shell..
No, the revo tires weight about 2.2 lbs per 4. Not a bad weight for wheels.
ncalenda
Need for Speed
ncalenda's Avatar
03.16.2007, 03:18 PM
Funny, true, maybe I will get some pics inside and under it.
ncalenda
Need for Speed
ncalenda's Avatar
03.16.2007, 06:58 PM
Here are some pics:
The front inside: The Front
Now, I do use 2 9V batteries to run my fans, I would rather do this then drain the 14-cell. I know this takes up weight, but not 2 - 3lbs worth. After seeing other trucks that weighed around 9 lbs, I couldn't believe mine was over 12 lbs, about 3 more lbs. That sounds like a lot to me.
Here are the rest
Let me know what you think, thanks!
squeeforever
03.16.2007, 08:00 PM
If you get G-Maxx skids and lose the center skid, you'll lose a few oz.
Finnster
KillaHurtz
Finnster's Avatar
03.16.2007, 09:03 PM
Originally Posted by ncalenda
Here are some pics:
Here are the rest
I would ditch the 9Vs. A 2 sec wheelie will drain more power than the fans will the entire run.
Otherwise you could do little stuff here and there. 12 lbs w/ the batts right? Each 7 cell should weigh ~1lb. So really you are ~10lbs, which is not that bad for a normal Maxx w/ a few alu parts.
squeeforever
03.16.2007, 09:39 PM
Mine was 8lb's with 12 cells, so its not really good...
Finnster
KillaHurtz
Finnster's Avatar
03.16.2007, 11:53 PM
Well no, not good, but stocker is 9.7 lbs w/o batts. so its not obscene.:005:
I have seen others as well who have gotten theirs down to 8 lbs and below w/ a combination of lightweight tires/rims, various gmaxx parts, ti hingepins/links replacing the steel stockers, 4 shocks, using plastic where ever possible, and trimming down plastic that isn't necc, etc. Although if he gets it too light the dog may win...
