Insides of a KB 45 xl motor -
01.04.2008, 11:25 PM
Not sure if anyone cares, but this is what one of these beasts looks like apart. The feigao motor behind the rotor is a 15l. The front end bell unscrews, quite easily on this one.
mine has came apart a couple of times on the shaft side. last time i used thread lock then soldered a small spot, then covered the seam with ca glue. its been holding since then, but i'm expecting it to come loose again. i would have done something better, but i was in the mood to bash, not wrench. its not coming apart from unscrewing either, it popped over a few threads which then allows it to move depending on accellerating or breaking.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
I've heard of the KB-45 motors being easy to take apart... My isn't so easy. In fact, I couldn't unscrew the front endbell at all, with the use of a rubber strap wrench and an adapter plate that basically stuck the front endbell to the vice.
That rotor is big, though!
