should i get these, what do you think
Maxxman
Question should i get these, what do you think - 06.26.2007, 02:41 PM
i was looking around for lipo's in england and i found some hyperion 5000mah 2s1p 7.4V batteries.
http://robotbirds.com/catalog/produc...oducts_id=1260
i thought that they looked quite good but wondered what you guys thought?
it is between: Trakpowers, these, or FLIGHTPOWER EVO25-5000 2S 7.4V 25C
Want to know which ones to go for?
MetalMan
MetalMan's Avatar
06.26.2007, 03:32 PM
Just so you know, the Flightpowers use the same cells as the Hyperions (both are Enerland cells). However, it seems that the cells in the Flightpower packs are a higher grade, or the pack build quality is better, since the Flightpower packs appear to allow for better power output.
Maxxman
06.26.2007, 03:45 PM
i thought that the specs looked quite similar when i was looking around.
i think they don't have the same balancing connectors but i am not sure so could someone verify this for me.
which ones would you go for MM?
at the moment i cant find any shop selling or listing the flightpower25-5000 so don't know which ones to go for.
what do you reccomend?
