Originally Posted by Trick440
What parts do I need to remove to change this?
You need to remove the bulkheads and disassemble them to get to the diffs just remember where everything goes.
once you get to the diffs remove the screws to the cases and take them apartand remove the diff. the diff has two different bearings so make sure you put them back in the right places.
remove the four screws that hold the diff together and remove the ring gear so you can see the insides of the diff.be sure to remove the seals and clean the all the metal and plastic with nitro cleaner
reinstall all the seals and reverse the disassembly. just remember where you took everything
as far as what exactly to remove i can't tell you, I just pull screws till i get to what i need to work on. I hope this helps.
