need help with Spektrum rx problem
Cartwheels
need help with Spektrum rx problem - 09.25.2007, 11:09 PM
On the plug where the ESC plugs into the receiver. If I push on the plug everything works correctly. After I hit a few bumps it stops working correctly. It comes down to, it's either a problem with the rx or with the plug. Where should I go from here? Should I just replace the rx? By the way is a 2ch sr3000.
09.25.2007, 11:17 PM
Carefully spread the wires on the servo lead and use a zip tie round the spectrum to hold in place..,
Cartwheels
09.26.2007, 12:06 AM
I did a little further testing. I hooked up a servo to that channel that I'm having problems with. The servo worked perfectly. I can wiggle the wire all day with no problems. The problem must be in the wire that goes to the ESC or the ESC itself.
Cartwheels
09.26.2007, 12:45 AM
Ok just found one of the wires that goes to the receiver was broken on the inside.
09.26.2007, 01:31 PM
perserverance wins!
