over heating my monster pro -
11.27.2007, 09:31 AM
hi guys i have a brushless gorrila max revo
i run a monster pro esc with rc monsters heatsink
the neu 2700 kv motor
strobe slipper ofna 51 t spur
17/18/20 t pinions
2x 7.4 /5000mah lipos i run them in series (14.8)
g max single speed converstion
40 series wheels with mulcher tyres
the problem is it doesnt matter what pinion i use i keep getting thermal cut off wich isnt good when its jumping
the lipos/motor /esc are all getting hot
i was told it might be the motor causing this so i was considering getting a new one but does any one have any more idears what i can do to solve this problem
A FAN??? Just a thought. When all else fails blow forced air on the electronics gear. Trying a different motor may be the only real fix though. If your configuration is setup correct then maybe there is a kink in the armor so to speak. You may have a weak link in your setup??
i am running 2 fans behind the esc heatsink and 1 on top of the of the esc
It might be the lipos. I had a set of 5000's from maxamps and they couldn't handle the draw from the MM on my Rusty setup. I ended up puffing one and the ESC was heating up constantly. It seems the discharge rating is over rated causing everything else to work harder.
Their was a thread here not long ago about the discharge rating on maxamp lipos.
So I switched to the 6000 and now more problems.
hi my lipos are the nosram 7.4 5000mah 25c i thought the c rating would have been plenty i ran the same system on my 1/8 lightning buggy with stock diffsand a 16 t pinion and had no over heating isues
Like I stated earlier it sounds like you might have a weak link in your system that is causing it to overheat. Bad connections are a number one cause of overheating, bad cells, bad motor, or a bad controller maybe. Process of elimination is your only recourse. If you are setup as you should be then it has to be a hardware issue. You might want to check each component out closer for individual problems.
Q. When the esc thermals, is the actual case hot, or mainly just the wires/exposed pcbs? Also, what is the weight of the revo compared to the lightning, that would be a big factor too in determining gearing.
IMO, the 2700 is a pretty high RPM motor. I know my 4s gets warm on the 1515 1/y, not bad at all though.
To me, it sounds like you are way over geared. I would go with 8000 maxamp packs. Gear it more conservatively with that wind you have. Right now, with the Lipo;s you have, you are hitting 39,000+ RPM, which is not bad, but I would drop that a bit more and get closer to 35,000. Go to Brian's calculator and see what you can do.
I agree with neweuser, I think your over geared. What sort of driving are you doing? For normal driving I think you need to go down at least 2t or so on the pinion and see how that goes. If you have a finned neu, the 17t pinion might be the smallest you can use with the ofna 51t without grinding fins. 1/8th diffs will help get your gear ratio down a little bit or you could try the 65t spur off an Ofna Monster Pirate I think it is. Motor plate may need modifying for that to fit.
