Feigao/Nemesis/Wanderer "XL" Brushless Motors
gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
Feigao/Nemesis/Wanderer "XL" Brushless Motors - 11.26.2007, 09:50 PM
What's the difference between these two?
http://www.rc-monster.com/proddetail...WAND_XL&cat=20
http://www.rc-monster.com/proddetail...540C_XL&cat=20
:D
rschoi_75
Certified Spaceball
rschoi_75's Avatar
11.26.2007, 09:56 PM
the built in heat sink.... that's about it.
rcm xt8
rcm xb8
rcm crt.5
gtxracer
gtxracer's Avatar
11.26.2007, 10:46 PM
Ah, so the ones without the heat sink are better when combined with Mikes heat sink/clamp?
:D
B15
11.26.2007, 11:43 PM
I think thats the general opinion, but there are good arguements for both can setups. The smooth can with the clamp heatsink almost definitely wont come apart, but the 540c can shouldnt come apart either because of its threaded endbells. Also the heatsink on the 540c should be more effective, since the fins cover more of the can surface. The problems with the 540c are that some of them do come apart, either because of poorly machined threads or lack of threadlock, and the slightly larger can diameter can be a fitment problem on some motor mounts.
gtxracer
gtxracer's Avatar
11.26.2007, 11:53 PM
Great info, thanks a lot B15!
:D
MetalMan
MetalMan's Avatar
11.27.2007, 12:11 AM
Only problem with the 540C motors, only the rear endbell is threaded on. The front endbell is pressed on similarly to the smooth cans, and can come apart.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
11.27.2007, 03:01 AM
Yuppers, the front of mine came off, so I just glued it....
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
