Hello,
i've got the same with a 22418 and 1521/1d with flightpowers 4900 4s,
the only way for me to solve the problem was to put the controller on "low rpm" mode or "race mode"; don't know if the problem comes from a bug of the controller, or if it's just
that the voltage of the battery falls down under high loads (in this case my solution wouldn't be recomanded).
Let us know the results if you try with bigger batteries...
Yea it is set up for 3s Lipo.
The battery was fully charged.
It will run at half throttle no worries, It is just when you give it full throttle the motor cuts out.
Bring it back to half throttle or less and it is away again.
It sounds a bit strange. Just thought I might of missed something in my programing.
(Programing by transmitter)
I have it programed to cut the motor off at low voltage but the battery still has 11.7V left in it.
I still suspect either the LVC (11.7V isn't exactly a fully charged 3S lipo pack) or a poor connection between the motor/controller.
things i would do;
-disable the LVC (what brand of batteries are you using?)
-Check the connections between the motor/speedo
-Check to see if the transmitters EPA is set to 100 percent
-reprogram
-try a separate receiver pack
-try a different radio
Thanks for the info.
I have it set for 9v cut off. the battery is at 11.7V only because I have been running around with it for a while trying to figure out what was going on.
Fully charged they are about 12.6V from memory.
The battery is a maxxamp battery.
I get the same problem if I go from 0- full throttle slowly or stright away.
I have just ben going over my instructions again last night.
It appears that I have missed a step in the programing ( programing by transmaitter)
Apparently I have to set the Automatics tunning when I have done everthing else.
It tells be to run the car at full throttle for a least 2 seconds.
Could this be the problem why I am not getting full throttle?
I can't try it out today as it is raining. will have to wait untill it clears up a bit.
Sounds like a LVC issue to me. You could always reprogram. Try it set to 6V and see if it works. The fact that it stops doing it in "race-mode" where all safeties are off tells you its a safety feature kicking in, and I don't think its a current limiter w/ your setup.
Thnaks for the info again.
I haven't set it to race mode as yet.
At the moment it is set on motor cut off when low voltage. ( should cut off at 9v) I think.
When you said to set it up for 6v to see what happens do you mean to set it up for 2 lipo instaed of the 3 lipo setting that i have it at now?
