Here's my setup. 3.3 chassis Revo with a 1515 1Y motor. I'm using a MGM 16018 controller with a 5S 6000mah battery.
I installed a JR DS8711 steering servo.
I didn't think this was going to be difficult but apparently it's beyond my comprehension level because I'm at a dead end trying to understand what I did wrong.
The controller has 5 wires. Obviously a positive and negative that goes to the battery. I soldered VXL Traxxas ends on the end. (correctly)
The other 3 ends received bullet connectors. I couldn't find anything that said which three wires off the controller went to which 3 wires on the motor.
I was told that it doesn't make a difference which one goes where and the worse thing that would happen is I may have to switch wires to change directions.
Is that correct?
I ask because when I hook everything up and try to enter programming mode (I don't have the laptop connection setup)
Next thing you know, it's smoking.
What the heck am I missing? Like I said, it shouldn't take a rocket scientist but I'm lost.
Smoke = bad. It's likely dead.
Don't power up any more until the issue is solved, and again it may be too late.
Post pictures that show your connections.
A few things.... first, here's some pics. I honestly don't see how it could be hooked up wrong but...
Second, I tried the programming again and at least this time, I can get a constant beeping. It beeps once and then goes into a equal constant beep. I thought I read in another thread that the voltage may be set wrong but obviously without cables, usb, etc, there is no way for me to change that.
Are those 6mm bullet connectors on the motor? If so why doesnt it look like its fully insulated with shrink tubing covering the whole bullet? Is it possible those shorted out against each other when you first turned it on, otherwise looks like everthing is correct.
I don't have tubing covering the whole thing. There's a 3/8" gap between the two. Though nothing is guaranteed, I did make sure it was apart from the other wires... anotherwards, no I don't think they touched.
Right now, I'm getting an error message (rapid beeping sound) . That's further than I got before.
You can change the battery type and cell count with the transmitter. There is no way to change the actual voltage per cell cut off (factory set at 3.1v).
Great... when you go to the next parameter, how do you know which "mode" you are in once you get into that parameter section?
I guess it doesn't matter. Since the factory setting is for Ni-Cd, I tried one instead of the lipo but it still wouldn't read it.
I just hope like hell I didn't burn out the ESC. I'm gonna send Mike an email. I'm not real happy since it seems that would have been something he would have mentioned.... cause God knows, the instructions that come with it are ridiculously written.
I had that problem onec. I just reprogreamed the ESC to my controler endpoints and then it all worked again. Just rerun the basic radio setup and see what happens.
to make it...
or break it...
As far as knowing what mode your in everything will be set to factory defaults as shown in the manual unless you have changed that setting. You do not need to know what any given setting is to make changes.
To program a feature just set to whatever # option you want. If you want the first push once then pull to set. This works no matter what that option may be set to when you start.
I would if I could.... The problem is I can't even get into programming mode because I using Lipos and the factory setting is apparently set for Ni-Cd.
I tried to use a Ni-Cd but that didn't work either.
Hope that helps.
So I should be able to get into program mode regardless of what settings are already set?
I'd love to but it gives me the rapid beeping after 10secs.
Suggestions?
Mark
PS. My radio is a Spektrum 3.0 and I had it replaced from the factory. Point is, it's BRAND NEW and I haven't changed any settings on it EXCEPT to bind the radio to the receiver.
I believe there is something that has to be done when using the spectrum radios. If I recall it has to do with the amount of time it takes for the RX to sync with the TX. My best guess would be to try connecting a RX pack to your receiver so that it will be powered up and ready when you connect the power to the MGM.
You can try searching the forums as I think this was a problem for some others also.
