outrunner for Revo on 4s ?
83gt
outrunner for Revo on 4s ? - 01.21.2008, 09:51 AM
Hey all. i'm interested in giving an outrunner a shot. Are there any inexpensive outrunners with KV's close to 2k that will be heavy enough for a Revo ? I'm only running 4s, so I'm sure that limits my outrunner options immensely. I used the motor selector and determined I need a KV from 1800 - 2200 or therabouts. If it's a bit lower KV, I can always gear up a bit I suppose.
Any ideas ?
J.
BL-Power
BL-Power's Avatar
01.21.2008, 11:01 AM
A 2200kv is spinning too fast on 4s Lipo,it is good for a 2s Setup. In general, you shouldn't take cheapo outrunners above 15000rpm and the better ones (AXI....) above 20000rpm. So look for a 1000kv outrunner on 4s Lipo and use largest pinion and the smallest spur gear you can find.
 Send a message via ICQ to BL-Power
83gt
01.21.2008, 11:14 AM
any recommendations ? AXI ? Has anyone tried the GP rimfire outrunners in a conversion?
BL-Power
BL-Power's Avatar
01.21.2008, 11:38 AM
You could use an AXI 2826/10, sikeston34m is using it in his E-Maxx on 4s Lipo with success: http://www.rc-monster.com/forum/showthread.php?t=9493
01.21.2008, 11:53 AM
+1 for the axi outrunners, for the price they are an excellent deal. I am very impressed with the construction quality. You should go with the 2826/10 it is a good motor for what you are looking to do. The 2826 is the stator diameter and length, the 10 is the number of turns. Longer stator-26- equals more torque in the smae diameter-28-. The 28 series have 5mm shafts and a 540 bolt battern, so they are a direct bolt in for a std motor mount.
83gt
01.21.2008, 11:57 AM
sweet, thanks. You think I would be happy with it compared to say a Feigao 8-9xl ? I can run it on the MM or Quark 125b.
J.
01.21.2008, 12:10 PM
On 5s lipo it will be good, the MM does not like outrunners, so the quark is your best bet.
jhautz
jhautz's Avatar
01.21.2008, 01:53 PM
http://www.horizonhobby.com/Products...dID=CYLCAR2000
This should work nicely. Just ask Sikston. He has my old one and loves it. I wish I never sold it to be honest. Great on 4 or 5s.
to make it...
or break it...
Silent...But Deadly
83gt
01.21.2008, 02:21 PM
Man, that looks perfect with the KV and all. Price is a bit high for what i was thinking for this project though. I'd like to stay around or below 100.
I also notice it has a 3mm shaft. All my 32p and Mod1 pinions are 5mm.
Know of anything similar with a 5mm shaft ???
J.
jhautz
jhautz's Avatar
01.21.2008, 02:26 PM
The crazy thing about that motor is its based on a 5mm shaft and its turned down to 3mm where the pinion goes on it. I think they were aligning it to work with stock emaxx pinions.
I think like most outrunners its just a matter of losening a set screw that holds the shaft in place and replacing it with a 5mm shaft that isnt turned down on the pinion end. Should be easy to do if you can find a 5mm piece of rod and cut it to length. I could be wrong on that, but I think that is the case on most Outrunners.
to make it...
or break it...
Silent...But Deadly
83gt
01.21.2008, 02:48 PM
hmm. i have 5mm shafts from a couple burnt up ammo's. I wonder if that would work ?
johnrobholmes
johnrobholmes's Avatar
01.21.2008, 02:54 PM
On 5s lipo it will be good, the MM does not like outrunners....
That may change by the end of today. Check for an update in 4-6 hours (if all goes well).
83gt
01.21.2008, 02:55 PM
I've seen a few outrunners on MM controllers. Not personally, but on the forums and such.
Would something like this be much too small ??
http://www.hobbycity.com/hobbycity/s...idProduct=2128
And has anyone tried these hybrid's yet ? Looks interesting, and the price is very attractive...
http://www.hobbycity.com/hobbycity/s...idProduct=5422
J.
johnrobholmes
01.21.2008, 03:24 PM
The gold outrunner is too small. When looking for a motor for your revo, keep the motor weight at least 8 ounces (224gm) IMO, if not 10 ounces.
01.21.2008, 03:28 PM
I would like to see some of those UH hybrid outrunners in action. I tried both align 600l and xl on 5s and they worked well for me in my old emaxx. They are around 1600kv and work well with a quark controller.
