Heat Shrink on MGM ESC
BashOn
Heat Shrink on MGM ESC - 02.01.2008, 01:03 AM
Anyone know what type of heat shrink they use on the MGM controllers? I slightly damaged the shrink on mine. It is no big deal but I was thinking of replacing it.
jhautz
jhautz's Avatar
02.01.2008, 02:03 AM
I dont know the answer to this question, but I would like to know also. It seems really good and id like to use it on other things too. I hope someone knows the answer to his.
to make it...
or break it...
Silent...But Deadly
CLB
02.02.2008, 12:29 AM
I opened mine up because I preferred the 3.5mm plugs to the wires. The shrink tube is only punched where you see wires entering. The open sockets you see are shrink covered. Motor and negative battery hook to far side. Positive battery hooks to near side.
Here is what I found:
Anything that fits will work. I used some clear 1.5" tubing. 1.25" would probably be better but I couldn't find any.
That said, the MGM controllers don't seem that well environmentally protected. The shrink tube is applied before the heatsinks are mounted. The area over the FET's is cut away before the sinks are mounted. Leaks will occur around the seam. Both ends are largely open.
It also appears that the coating is missing in the inboard sections of my "marine" controller. I.E. the center of the boards are bare. I had a bottle of mil-spec acrylic coating so I gave the boards a good dunking before re-applying the shrink wrap.
Before applying the wrap I cut a plastic end cap for the data port end of the controller. I punched screw holes (only) through the shrink wrap instead of removing the area over the Mosfets. I am sure the shrink wrap adds a little thermal resistance but the FET's already dump heat through lead frames, PWB's and epoxy encapsulation. I doubt the added barrier makes much difference. I would rather have the environmental protection.
I used a little coating on the seam between the shrink tube and the end cap. I still have to RTV seal around the caps. A little tape over the program port and it will be pretty well dunk proof.
'nuther view:
BashOn
02.02.2008, 11:27 PM
Awesome info CLB
CLB
02.03.2008, 12:41 AM
The above pix are for my 160/18
The link below shows an issue (and incomplete coating) my 120/18 had.
http://monster.traxxas.com/showthread.php?t=400483
Serum
Serum's Avatar
02.03.2008, 04:32 AM
Yeah, i know what heatshrink that is, that's just the ordinary shrink as put around wires, i can get it here pretty simple. It's the same stuff schulze uses.
