BEC and Novak HV system
Gee
A Horse's Ass
Gee's Avatar
BEC and Novak HV system - 02.18.2008, 05:34 PM
Can you run a BEC with a Novak HV 4.5 setup?
Sorry I found it
If using an external receiver battery pack with the HV-Maxx ESC:
1. Plug an external 5 cell (1.2VDC/cell) receiver battery pack into
the battery slot of the receiver.
2. Leave the HV-Maxx’s ON/OFF switch in the OFF position, and
use receiver battery pack’s ON/OFF switch to turn the system
power on and off––Do not use the ESC’s switch.
12VDC BATTERY NOTE: An external receiver battery pack should be used
when using the HV-Maxx with a single 12 volt battery, like a lead acid or
gel cell. The ESC’s built-in B.E.C. will provide limited output due to the
high voltage directed through the single battery input, resulting in
degraded servo and receiver performance.
Any comments though?
