my mgm is starting to build higher temps
tashpop
my mgm is starting to build higher temps - 02.24.2008, 12:43 PM
i noticed my mgm is getting into the 160 range.it didn't used to. i know i need to get new bearings for my motor, but also i just switched to a digital steering servo. i was thinking that maybe i could help things out by installing a ubec. you guys think that would make a nice difference in my temps?
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
jhautz
jhautz's Avatar
02.24.2008, 01:36 PM
Do you have one of the newer ones with the switching BEC in it? If you do, the external BEC shouldnt matter.
Check to see that the heatsink scews are tight. I read somewhere in another forum that somebody was having issues with this and their heatsink screws were loose and it effected the cooling.
Also check that you didnt blow a capacitior. That could cause it tor run hot as well.
to make it...
or break it...
Silent...But Deadly
david lamontagn
02.24.2008, 02:53 PM
When i've recieve my MGM from RCM, 3 of the 8 screw that hold the head sink was loose.
I've remove all 8 screws and place a little , very little amount of blue locktite on each screw.
And for the BEC, i've the new version with the internal switching BEC but i run it with an external CCBEC.
Just a question of choice
tashpop
02.24.2008, 05:51 PM
its the version 3 if thats the new one. i believe its a switching.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
