MGM 16018 auto-tuning problem
david lamontagn
Question MGM 16018 auto-tuning problem - 05.02.2008, 11:53 PM
Hello, i've run my MBX5T today with the Neu 1515 1Y, FP 4s and MGM 16018 with the new software. It's killer!!! Lot of power, it's unbealevable.
But after the first run, i've decided to perform an automatic tuning on the controller, but when i've try to write the data on the controller, he beeeeeeeeeeeeeeeeeeeppp and never stop of beeeping. I've disconect the USBCOM+ from the controller and try to give it a run as they said in the manual, but nothing when i pull trigger, and the controler keep beeping.
So i've reconct the controller on the USBCOM+ module and put it in CAR forward mode, write data, motor beep tree time and all was correct.
Why the controller don't want to go in auto-tuning????
The only reason i can see is that i've not perform the auto-tuning at very first time that i've run the controller and after that, he don't want to did it.
But if it's for this reason, do they have a trick to "reset" the controller and do an auto-tuning???
Another question, when i pull trigger, seem to have a light deadband before the car start to move,,,,why??? Is the range of neutral zone who's not right setting?? which the better setting for neutral zone??
Thank you!
David
