xt8 1521 6s mgm brake setting help it!
masense
xt8 1521 6s mgm brake setting help it! - 05.10.2008, 04:59 AM
hi every one!
My E REVO is extremely smooth with mechanical brakes.
When I return a throttle, XT8 strongly takes too much brakes.
What will you do?
Cannot you but make it mechanical brakes?
neu1521 6s mgm 16018 cc ubec
pinion 17/48
rear centerdiff front oil 10000 30000 10000
futaba 3pk super
mgm Para-meter
a 3
b 4
c 4
d 1
e 1
f 6
g 6
h 1
i 2
j 1
Thank you by good advice
lutach
lutach's Avatar
05.10.2008, 01:53 PM
I think (I'm not sure) that the new firmware allows you to disable the brakes on the controller and that will allow you to stop your controller from braking.
masense
05.10.2008, 07:53 PM
Thank you for an answer!
When they return a throttle when they remove brakes, brakes do not work.
I wanted to do something with ESC brakes if possible.
I remove it and cannot but do brakes on mechanical brakes?
