need crt help
droopy
need crt help - 05.10.2008, 08:28 PM
I know this probably sounds dumb and your shaking your head but how the heck do you take the center diff apart?? I guessing you take out the set screw is there a pin in there that comes out if so hoe do you get it out.
Electric Dave
05.10.2008, 10:32 PM
Jammin has the full downloadable manual on their site, I'd highly suggest getting it and printing it out. Makes wrenching much easier.
05.10.2008, 11:04 PM
Take the 4 screws out of the spur gear, and then remove the spur, then remove the 4 spider gears and shafts, then pull the output gear out of the botton of the diff cup. The set screw is there so that you can get the cross pin out that holds the diff output in on the cup side.
