ax-10 build
Life_livin
ax-10 build - 05.11.2008, 08:47 PM
Hi my name is nick this is my first post and for my birthday i got $501 and i am going to buy a axial ax-10 and i am going do use my old tq3 radio and get the novak 55turn combo. I am going go get pro-line flat iron tires(or just memory foam) the rock craw;ing chevy c-10 body is there any other things that would be good cheap hop ups that i should put on while building? I am 11 so take it easy on my if i am slow and this will be my first kit.
johnrobholmes
johnrobholmes's Avatar
05.11.2008, 08:50 PM
You will probably want aluminum knuckles and rear lockouts. I broke my rear knuckles pretty fast. Otherwise the shocks suck but will work at first. Everything else is pretty solid- axial did a great job when they made the kit.
Also, pick up a set of lockers. The Axial sintered metal or any aftermarket will do. The aluminum ones in the kit eat out pretty fast.
---JRH---
Life_livin
05.12.2008, 12:48 AM
thanks you is the 55t novak crawler set up good? and do the rock lizards grip up and also are the foam really solf or would i cut them star pattern or jsut go with memory foam
gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
05.12.2008, 09:06 PM
Don't use the stock tires or body for that matter. Get some Losi Rock Claws or Proline 2.2 Badlands. Bent links, etc are good for it. Check out www.rccrawler.com/forum for a TON of Axial info.
:D
