eagle tree loggers -
08.13.2008, 09:39 PM
mike can you get eagle tree loggers?
also for the guys useing them, can you log 3 temps at once with them?
thanks
08.13.2008, 09:55 PM
Not sure about older ones, but a quick glance at the eagle tree website tells me the eLogger v3 has 3 temp inputs.
I think I read somewhere that you can use one of the Temp sockets to log a second RPM as well.
08.13.2008, 10:19 PM
thanks sammus
so i need a v3 mike
08.13.2008, 10:25 PM
On that note, I'm not even sure the earlier versions are available anymore :)
I know towerhobbies sell them, I got the 150A model, plus the lcd and a heap of sensors for ~$130 delivered to to me here in Oz...
Yip Yip Yip...
08.13.2008, 11:20 PM
I bought a clear plastic case from jaycar and have packed mine into that. It isn't that small anymore but I thought it would be best when running that screen.
JERRY2KONE SUPERMAXX
08.14.2008, 12:36 AM
I just checked out the EagleTree system at Tower Hobby at (Eagle Tree Systems Seagull Pro Wrls DshbrdFlghtSys2.4GH) it is the version 3 system and it runs $599. Kind of pricey, but what are you giong to do, right? I guess if you want it bad enough you will pay the big bucks for it. Once I start getting all of my projects up and running I plan on having one in hand. Good luck and let us know how that works out for you.
08.14.2008, 12:38 AM
I'm pretty sure you can plug the screen in after a run and itll tell you what you want, doesnt need to be hooked up the whole time :)
Wow I wouldn't bother with that, I think the eLogger V3 is ample for my usage, and nearly 1/10 the price too :P
Also -
08.14.2008, 12:43 AM
T/H also has the V2 stuff still on the shelf at lower prices that will probably fit the bill for whatever you are trying to do. They also have a lot of the individual components for sale if you wish to piece your own system together a little at a time.
08.14.2008, 01:31 AM
thanks jerry, you just saved me alot of money
08.14.2008, 01:42 AM
Is there any reason you wanted that $600 setup over the $80 elogger?
Nothing To It. -
08.14.2008, 02:12 AM
Hey SemiPro all I did was share some info with a fellow RCM brother. That is what we do here. I to hope to purchase some EagleTree stuff down the line and any info on their gear is helpful. I hope that you find what you are hoping for. That $600 system that I found was the PRO V-3 version, which I would assume is their top of the line stuff. Still I think that everything that you may want is on the T/H site. They do carry a lot of good gear for fair pricing just like RCM MonsterMike does. Glad to be of assistance.
Yip Yip Yip...
08.14.2008, 02:18 AM
The main thing the $600 setup does is feed the info back to the transmitter.
Sammus I didn't even think of just plugging the screen in at the end. I know the screen only shows current session stats but as long as you don't disconnect the eagle tree from the battery before plugging in the screen it might work. I'll run mine with the screen connected though cause I have the space in most of my cars.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
