FLM SPV2 Crawler Build - Designer StampedeProject
stampedeproject
stampedeproject's Avatar
FLM SPV2 Crawler Build - Designer StampedeProject - 10.08.2008, 05:16 PM
Born out of a a want and need for a more universal style chassis, I developed and designed the SPV1 and SPV2 chassis. Currently the designs are licensed to FLM (Fast Lane Machine) and now available from RC-Monster.com
It all started when I heard of Losi's mini-crawler several months back. I though a mini-scale crawler would be cool, but how about a true 1/12th scale... durable and easily built based via Wheelie King parts, a Traxxas Stampede tranny and whatever else I had laying around. The result was my below 1/12th scale FrankenCrawler with parts from just about everywhere. The FrankenCrawler was very capable considering it has a Stampede tranny, Wheelie King axles, mix and match driveshafts, EMaxx Shocks (later Axial Shocks) and of course the original prototype of the SPV1 chassis.
It suddenly occurred to me that if a plate style chassis was flexible enough it could be used on anything from a mini to super class builds and satisfy everyone from the Clod, Berg, Wheelie King, Axial, and other builds with about every hole you could need all in one chassis and still be USRCCA compliant. The result was the SPV1 & SPV2 - StampedeProject Version 21Chassis shown here with the original black Derlin prototype. The SPV1 was designed specially as a bolt up replacement chassis for the stock Axial chassis.
I worked up the first below test version on CAD and had Jamie at FLM cut the blank. I mentioned to Jamie that John Robert Holmes would provide un-hindered feedback and we ended up with the second version thanks to some excellent recommendations from Holmes. What we realized was that not everyone wanted all the prolific perforations in the chassis and extreme adjustment capabilities probably were not needed for most people, but we decided to offer two chassis side plate versions one Universal chassis with all the holes in the below chassis, and then a cleaner Standard version like the one Holmes ran at nationals and pictured a little further down. We also beefed up the lower windowsill and moved the front windshield forward for those people that are running a slipper clutch. The chassis plates will all bolt directly to a stock Axial chassis.
[Below is the original Universal SPV2 Prototype]
Another thing Holmes pointed out right away was how cool the chassis worked with on a Berg setup. We are going to offer the chassis in either Universal (above) or the less holy Standard version (shown below on Holmes chassis running Nationals in Moab with a Berg setup) with either Axial width chassis spacers or narrower spacers for Berg, Clod, Gmade or other Dual tranny builds.
Below represent the final two chassis plate designs with each offered in either 55mm or 81mm (Axial width) spacers. The SPV1 is the more holey (highly adjustable) plate design and the SPV2 is the version that still provides plenty of tuning flexibility, but cuts down on the holes in the chassis.
The Marketing Info I wrote to explain the different versions.
FLM's SPV1-81 & SPV2-81 Rock Crawler Chassis - For AX10 & Other Driveshaft Crawlers
This super light and durable 81mm spacer width chassis is specifically designed as a direct bodiless stock chassis replacement for the Axial Scorpion AX10 using the stock skid plate. The chassis also works great for anyone doing a custom HPI Wheelie King, or Tamiya TXT/TLT rock Crawler build. The milled 81mm chassis spacers are drilled, tapped and ready for your body panels or scale accessories to be mounted. Both the SPV1-81 and SPV2-81 chassis will accommodate Axial, Losi Crawler, EMaxx and other similar rock crawler shocks in both sprung and droop crawler suspension configurations. For those wanting the ultimate in mounting flexibility, the SPV1-81's extra tuning holes will provide the customer crawler builder nearly unlimited tuning options. This chassis conforms to the 2008 USRCCA chassis rules for competition with required hood, roof and door body panels (not included) installed. The SPV1 and SPV2 chassis are StampedeProject.com designs.
Approximate Weight 5oz.
SPV1-81 & SPV2-81 Chassis Include:
Chassis plates
Seven (7) - 81mm Milled Chassis Spacers
Fourteen (14) - 3mm Machine Screws
Four (4) - Milled Shock Mount Offsets
FLM's SPV1-55 & SPV2-55 Rock Crawler Chassis - For 2.2 Class Berg & Clod Crawlers
This super light and durable 55mm spacer width chassis is specifically designed as a direct bodiless chassis for Berg and Tamiya Clodbuster style rock crawler builds. The milled 55mm chassis spacers are drilled, tapped and ready for your body panels or scale accessories to be mounted. Both the SPV1-55 and SPV2-55 chassis will accommodate Axial, Losi Crawler, EMaxx and other similar rock crawler shocks in both sprung and droop crawler suspension configurations. For those wanting the ultimate in mounting flexibility, the SPV1-55's extra tuning holes will provide the customer crawler builder nearly unlimited tuning options. With the included 8mm body panels spacers installed and required hood, roof and door body panels (no included), this chassis conforms to the 2008 USRCCA chassis rules for competition. The SPV1 and SPV2 chassis are StampedeProject.com designs.
SPV1-55 & SPV2-55 Chassis Include:
Chassis plates
Seven (7) - 55mm Milled Chassis Spacers
Four (4) - 8mm Milled Body Panel Offsets
