Pics of my 8ight Tekno VC3 Neu
Ryu James
Ryu James's Avatar
Pics of my 8ight Tekno VC3 Neu - 10.05.2008, 03:08 AM
The most recent variation of my 8B after modifying my third MMM and switching from 1512 1.5D to a 1515 1.5D....just for the hell of it.
Includes:
Lunsford complete titanium screw kit
Lunsford titanium hingepins and turnbuckles
Fioroni lightened shocktowers, top plate
Fioroni Tractive IV differentials front, center, rear
JR 9100s servos
aluminum parts here and there
I have been very pleased with the Tekno RC BL conversion. i have seen other companies conversions at the track and they dont look as nice IMO. The chassis, mechanical brake, and Neu motors are a beautiful feature of the Tekno setups. I use the long shank pinion over the elektri-clutch as it sounds much cleaner. (that clutch is noisy!)
The next project is going to be the 8 Truggy with the Tekno conversion and a CRT .5 with the RC Monster setup...if i ever see it in stock again. Cant wait!!
ID:	5524   Click image for larger version
ID:	5525   Click image for larger version
Jammin SCRT10 Neu 1512 1y
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
10.05.2008, 04:34 AM
So how does it go with the 15 over the 12?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
Ryu James
Ryu James's Avatar
10.05.2008, 12:46 PM
i honestly cant really tell a difference. the 1512 had i a little more speed at the top. the 1512 1.5D is 3200 KV and the 1515 1.5D is 2700 KV. they boh are phenomenol motors.
10.05.2008, 03:28 PM
Very nice buggy!
jnev
jnev's Avatar
10.05.2008, 05:19 PM
Awesome looking buggy! Have you noticed a big difference with the Fioroni Tractive IV differentials over the stock ones?
Ryu James
Ryu James's Avatar
10.06.2008, 04:29 PM
i have read that the Tractive IV diffs make it grip a lot better in the corners and make it easier to drive but i never actually drove the buggy with the stock stuff. i just threw the tractive IV in there right from the beginning. i would like to have someone drive it that has a lot of experience with the 1/8 buggies and see what they think. i am hoping to do that next time i am at the track and get a professional opinion. i will post the results when i do.
DRIFT_BUGGY
10.06.2008, 07:00 AM
What about temps and run time between the 2 motors?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
10.06.2008, 06:34 PM
Nice...you are one of the only ones that I have seen running a fan w/a Neu motor. My 1512 1.5.yf doesn't break a sweat on 4+5s.
Ryu James
Ryu James's Avatar
10.06.2008, 07:39 PM
nice buggy. what kind of difference do you see from the 4s vs the 5s? i am wanting to run a 5s on this setup to see how it does. the motor can totally handle it. and you have a MMM and a MGM esc? i had another thread asking for advice about the MGM controllers. how do you like it compared to the MMM? which MGM do you have?
stum
10.06.2008, 06:49 PM
Ya Neu's don't need cooling like that unless your gearing is off the charts.. I run a Medusa v2 60mm 2000kv on 4s lipo in my v3 e-8ight buggy geared 16/48 and it's flies and I can drive all day and this motor isn't 1/2 as good as the Neu 1512's.
I have the same conversions but I love the electri-clutch as it tames the intense torque for perfect racing.. if I wasn't using it as a race only buggy I guess I would most likely use the long shank pinions as well. I will agree it is a little loud but it is still silent compared to the rest of the nitro's on the track.. couldn't hear it if you wanted to.
Ryu James
Ryu James's Avatar
10.06.2008, 07:35 PM
yeah, when i had the 1512 in it never got very hot at all. i added the fan when i put the 1515 in just for kicks. i run just a regular gearing 13/48 i think it is. maybe its 13/47. the other night after 20 minutes the motor wasnt even warm. but i am thinking of trying a 5s in this setup as the motor can handle it.
hey, how do the nitros stack up against your BL? what kind of setup do you run? obviously its a tekno but what motor, battery, etc?
stum
10.06.2008, 07:45 PM
Here she is before the MMM went up in smoke...
Here she is now with the trusty MM w/ bec :P
Ryu James
Ryu James's Avatar
10.06.2008, 08:01 PM
dude, i tried the "trusty" MM with separate bec as recommended by the TEkno guys and as soon as i gave it some juice it blew up!! sent sparks 3 feet in the air. glad to hear yours is working out.
stum
10.06.2008, 08:43 PM
Sounds like you didn't unplug the red wire on the ESC when you connected it :P Too many volts messing there = dead esc
Ryu James
Ryu James's Avatar
10.07.2008, 04:37 AM
i unplugged the red wire. it was all setup right. at least thats what i was told. everything ran fine. fans came on, servos, reciever, esc all worked. i was actually about halfway through programming when it blew up. i pulled the throttle to confirm one of the functions and...boom! but up until then it was working fine. LEDs worked and it beeped as i went thru the programming steps. anyway, wont be trying that again. luckily now i have a MMM that is working. i am just going to keep using those. i hope this one lasts but if it goes out then i will just buy another one, and another one after that. i figure that eventually i will get one that lasts or eventually Castle will figure it out. either way, i will end up with a working esc in the end.
