What could be wrong?
Stregone
What could be wrong? - 05.29.2009, 06:26 PM
I just got an ezrun 60A esc and a kd36 3500kv motor. I've been waiting a month to get this up and running because the first esc got lost in transit from china, ugh.
So I solder all the connectors on, connect the motor, battery, and start programming it. First time I mess up and do things in the wrong order, but the motor did run and it was beeping when the set button was pressed in during calibration. I turn it off and try again, and there is no beeping. The flashing LED indicates I am doing it correctly, but the motor does not run after I am done. Any ideas?
I am going to swap things around to do some troubleshooting, using a friend's equipment. But I don't be able to for a few days.
