Crt X1 To Bce Pjx Chassis ??
CRTIM
Crt X1 To Bce Pjx Chassis ?? - 11.04.2008, 01:36 PM
Hey guys ,i'm just about done with my CRT X1 conversion ...i'm thinking now i want to upgrade to either the X2 chassis or the BCE PJX ...iv'e already done the small gear conversion so that won't be an issue...to you guys familiar with the BCE chassis should i go with the X2 parts or the BCE chassis ??...the X2 parts will be cheaper then the BCE chassis but if i'm gonna do this conversion i want to do it right....thanks for any help or advice
cheesecake
11.05.2008, 02:28 AM
There the same chassis jammin copied bce's design on it but it depends on if you need the width. the jammin chassis is a little wider compared to the bce. i know the bce chassis would probably last longer because of better quality so its basically up to if you need the little bit of extra chassis space
CRTIM
11.05.2008, 03:56 PM
thanks cheesecake for chiming in ,i was hoping you would sense i seen over at truggyracer that you had run the BCE at one point...yes,the width of the BCE is a concern ..by looking at some of the pics i was wondering if my RCM battery try was gonna fit ,so thanks for that info and your help as always
cheesecake
11.06.2008, 01:25 AM
not a problem. you should just get the jammin chassis so you know you have the width for the tray
CRTIM
11.06.2008, 04:43 AM
yeah ,thats what i decided to do to be on the safe side....pretty much got everything i needed to convert to X2 on ebay.....thanks a ton for the help
