Fm radio
_Bo05Ted_Fox
Angry Fm radio - 11.25.2008, 12:55 AM
Ok I was messin with my truck today and i rolled it. So when I go to turn it over it has no radio connection So Im thinking its the reciver. I go buy another reciver and its giving me the same problem. Could the esc (MM) be messed up in any way. The radio is a mx-3 fm 3 ch reciver combo. Could you break a crystal ????
Help me
11.25.2008, 08:33 AM
Diagnostics...
Does the MM power/light up at all?
-If no check your MM switch
Is your RX / Servo powered?
- If no check the lead from MM to RX or RX Pack/UBEC
Does your servo move with TX input?
- RX or crystal broken
Rgds
_Bo05Ted_Fox
11.25.2008, 02:37 PM
When I power up the mm it blinks the 3 lights like it has no rx input/signal. The servo and the bec are working correctly but the tx can not move the sevro in any way this is why I was thinking it was the rx but i replaced that and no change. Is it possible to break a crystal? That seems to be the last thing unless I somhow broke somthing inside the esc...
11.25.2008, 02:52 PM
Sounds more like a loose wire in the rx lead- check the pins are fully seated into the plug, and that they inturn seat fully into the rx it self. While you're at it, check all the wiring over for damage- could be the crytal, but unless you have a spare to check the orginal against, you may have trouble finding the route of the problem (besides bad driving skills ). You lhs should be able to help with crystals if needs be.
_Bo05Ted_Fox
11.25.2008, 03:37 PM
The pins seem to be fully seated in the rx but when I plug in an am radio system its the same problem. Then I pluged in a nitro car ebec to diecretly power the reciver thinking its the bec but only servos power up but still no movment from the tx. Could it be the esc ???
Gee
A Horse's Ass
Gee's Avatar
11.26.2008, 03:17 PM
If you plugged a battery pack into the receiver and the servo worked then it doesn't sound like the receiver. You can check the esc's channel by plugging the steering servo into the esc channel and use the battery pack. If the servo moves when you use the throttle your receivers fine. Check the wires coming off the board on the MM. There's the two for the switch that can become loose and create problems.
_Bo05Ted_Fox
11.26.2008, 04:03 PM
We figured it out finnaly. My friend motoman and I figured it out. It was the crystals The only bad part is my hobbyshop is about as useful as foamhammer. Looks like i will be ordeing some crystals from somewhere. Anybody have some ch 86 crystals laying around.....
11.26.2008, 04:49 PM
I have some ch. 72 crystals. Pay shipping and they're yours.
_Bo05Ted_Fox
11.26.2008, 11:37 PM
Are they 75 mhz still
11.27.2008, 11:34 AM
Yes.
_Bo05Ted_Fox
11.27.2008, 04:38 PM
Pm sent
11.27.2008, 07:03 PM
replied
