Outrunner repair
DLS II
Outrunner repair - 01.05.2009, 10:29 AM
Hi, I'm working on a Rimfire 35-36-1000 outrunner. In the process of centering the shaft so it can drive off both ends, the end piece that holds the shaft came loose from the magnet housing. Does anyone know what kind of glue I should use to put it back on?(yes it was glued on) I was thinking J-B Weld. Thanks, Don
pedeboi364
01.05.2009, 04:08 PM
JB Weld or good epoxy should do it
Check out my FS thread in the General Discussion!! Help me go lipoly!!!
DLS II
01.05.2009, 05:10 PM
Thanks, Don
MetalMan
MetalMan's Avatar
01.06.2009, 02:16 AM
JB Weld is what I used on one of my motors, and it's held up fine. Just make sure not to use too much (but use enough) and wipe off the excess so you don't ruin the balance of the magnet housing.
crazyjr
crazyjr's Avatar
01.06.2009, 03:45 AM
I have used JB Weld on two rotors in different motors (Novak hv bonded and a Lehner basic xl 1200) the 1200 is still running after 8 months of abuse
DLS II
01.06.2009, 05:19 PM
I used JB Weld. It looks solid. It's for a future project car. I want to build a TC3 with an outrunner in the center-should be a lot of fun! Don
